주요 콘텐츠로 건너뛰기
Car and Truck Wiper Blades Replacement
필요한 것
  1. Car and Truck Wiper Blades Replacement, Wiper Blades: 1 단계, 이미지 1개 중 1개
    • Lift your wiper blades off the windshield.
  2. Car and Truck Wiper Blades Replacement: 2 단계, 이미지 1개 중 1개
    • Cover the windshield with a towel or blanket to avoid shattering the windshield if the wiper arms come down accidentally after the blades are removed.
  3. Car and Truck Wiper Blades Replacement: 3 단계, 이미지 1개 중 1개
    • The wiper blades are typically connected to the wiper arm with a hook type of closure. Lift the plastic cover and slide the wiper backward to disconnect and carefully remove it. Repeat for the other side.
    • Unpackage your replacement wiper blades, and carefully lift the plastic cover covering the hook connector.
  4. Car and Truck Wiper Blades Replacement: 5 단계, 이미지 1개 중 1개
    • Slide the hook from the wiper arm into the wiper blade and tug slightly until securely connected. Replace the cover and repeat on the other side.
  5. Car and Truck Wiper Blades Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the towel from the windshield and lower the wiper arms back onto the windshield.
    • Test the wiper blades to ensure they're securely connected and working properly.
결론
When in doubt, consult your owner's manual or the back of the wiper blade package for further instructions.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Chaya Milchtein
회원 가입일: 07/06/23
1,057 평판
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 40
지난 30일: 65
전체 시간: 757
