주요 콘텐츠로 건너뛰기
Carburetor Cleaning
필요한 것
  1. Carburetor Cleaning, Air Filter: 1 단계, 이미지 1/3 Carburetor Cleaning, Air Filter: 1 단계, 이미지 2/3 Carburetor Cleaning, Air Filter: 1 단계, 이미지 3/3
    • Before starting, ensure that the engine is not running and is not hot.
    • Pull the tab until the filter cover opens. Remove the filter cover.
    • Note that the bottom of the cover is hinged.
  2. Carburetor Cleaning: 2 단계, 이미지 1/1
    • Remove the air filter.
    • The air filter will be either an oily sponge, or an accordion-folded fabric.
    • Note that the air filter is saturated with oil. Wear gloves and use paper towels to avoid creating a mess.
  3. Carburetor Cleaning, Carburetor Cleaning: 3 단계, 이미지 1/3 Carburetor Cleaning, Carburetor Cleaning: 3 단계, 이미지 2/3 Carburetor Cleaning, Carburetor Cleaning: 3 단계, 이미지 3/3
    • Locate the four bolts holding the air filter housing to the engine. Remove these bolts using the ratchet driver and the appropriately sized socket.
    • Remove the 1/4" bolts.
    • Remove the 5/16" bolts.
  4. Carburetor Cleaning: 4 단계, 이미지 1/2 Carburetor Cleaning: 4 단계, 이미지 2/2
    • Lift away the air filter housing.
    • Note that the housing is still attached to the engine via a bendable plastic rod.
  5. Carburetor Cleaning: 5 단계, 이미지 1/1
    • Spray carburetor cleaner into the open carburetor.
    • You may want to wear gloves for this step, as carburetor cleaner is harmful if applied to the skin.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ethan Narad
회원 가입일: 04/19/18
529 평판
안내서 3개 작성하였습니다
Cal Poly, Team S25-G15, Maness Spring 2018 Cal Poly, Team S25-G15, Maness Spring 2018 회원
CPSU-MANESS-S18S25G15
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 16
전체 시간: 1,609
