주요 콘텐츠로 건너뛰기
Carburetor Disassembly
필요한 것
  1. Carburetor Disassembly, Remove air filter + housing: 1 단계, 이미지 1/3 Carburetor Disassembly, Remove air filter + housing: 1 단계, 이미지 2/3 Carburetor Disassembly, Remove air filter + housing: 1 단계, 이미지 3/3
    • Use a 5/16 socket or flat head screwdriver to remove the first bolt. Pull the cover off and remove the air filter.
    • Remove the 3 bolts using a 5/16 socket. In addition, pull the breather hose off the assembly at the bottom left. Now pull the cover off.
  2. Carburetor Disassembly, Remove carburetor: 2 단계, 이미지 1/3 Carburetor Disassembly, Remove carburetor: 2 단계, 이미지 2/3 Carburetor Disassembly, Remove carburetor: 2 단계, 이미지 3/3
    • Remove the two bolts holding the carburetor to the engine with a 3/8 socket or wrench.
    • Remove the spring boxed in red from the hole. Pull to left of carburetor, towards the link the other end of the spring is around.
    • The link will be connected to the carburetor. Pull the carburetor off in an "S" motion and remove it.
결론
Jacob Micallef
회원 가입일: 03/06/17
993 평판
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 36
전체 시간: 1,133
