소개
In this guide, you will be instructed on how to adjust and synchronize the output of the two carburetors.
필요한 것
Use a 3/8 socket wrench to loosen the retaining bolts on the air cleaner.
Rotate the air cleaner so that the throats of both carburetors are clear. Now you will be able to adjust them.
Start the engine
Finally, raise or lower the idle speed screws until the idle speed is about 550 RPM
Rotate the aircleaner back to its original position, and re-tighten the 3/8 nuts on the retainers
hao ,jiu shi zhe yang
what if your getting air suction on the left one and not on the right one
Congratulations, your Corvair should now idle properly. If the Carburetors are still not operating properly, then the linkage is not synchronized, or they are in need of repair or rebuild. (A linkage adjustment and rebuild guide will be made soon!)
다른 26명이 해당 안내서를 완성하였습니다.
댓글 한 개
Bonjour,
Ma corvair a 4 carburateurs.
Est-ce que le ralenti se règle individuellement sur chaque ?
Merci
