주요 콘텐츠로 건너뛰기
Cardo Packtalk Battery Replacement
필요한 것
  1. Cardo Packtalk Battery Replacement, Remove Case Screws: 1 단계, 이미지 1개 중 1개
    • Insert wisdom here.
  2. Cardo Packtalk Battery Replacement, Open Case Carfully: 2 단계, 이미지 1개 중 1개
    • Take lower section off first, take care not to strain the battery wires
    • Some people simply cut the old battery wires and heat shrink them to new battery wires to avoid having to re-solder the small solder points on the PCB.
    • If you want to ensure your unit stays waterproof, you can add a thin line of silicone seal around case prior to reassembly
결론
작성자
1다른 기여자 명과 함께
FJrider
회원 가입일: 02/16/16
300 평판
안내서 1개를 작성함
2가이드 댓글
Can you recommend a battery to purchase for the Packtalk BOLD? Thanks!
Tony Psaltis - 답글
I can't recommend a particular one, when my Smartpack battery died I cannibalized an OEM battery from a broken Packtalk unit.
Here are a couple batteries on offer from Ebay and Amazon that claim they fit the Packtalk and have some good reviews (do your own research):
-https://www.ebay.com/itm/156144503815?mk...
-https://a.co/d/fuu9s9K
FJrider -
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 25
지난 30일: 157
전체 시간: 2,745
