소개
Many of the CC-EKV8SS7 replacement guides require that the bottom of the base be removed. This guide will demonstrate the steps necessary to do so.
필요한 것
Remove the five (10mm) Y screws from the bottom of the base. Three are in a triangle around the center and two are on the corners of the flat edge.
Now you will need to 'unlock' the top and bottom of the base from each other. On the flat edge, there is a rectangle inset with one side cut out. Insert a metal spudger about 1/2'' in to the opening to toggle open an interior tab.
With the metal tool still inserted, use an opening tool between the black and silver sides to pry the base open.
다른 2명이 해당 안내서를 완성하였습니다.
