주요 콘텐츠로 건너뛰기
Carrera Mario Copter Motherboard Replacement
필요한 것
  1. Carrera Mario Copter Motherboard  Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the quadrocopter over so that the underside of the device is facing up.
    • Unplug the battery cable from the socket on the quadrocopter.
  2. Carrera Mario Copter Motherboard  Replacement: 2 단계, 이미지 1/1
    • Push the battery upward with your thumbs to loosen it from the tight slot until your thumbs can not reach the bottom of the battery anymore.
  3. Carrera Mario Copter Motherboard  Replacement: 3 단계, 이미지 1/1
    • Pull the battery away from the slot to remove it.
  4. Carrera Mario Copter Motherboard  Replacement, Motherboard: 4 단계, 이미지 1/2 Carrera Mario Copter Motherboard  Replacement, Motherboard: 4 단계, 이미지 2/2
    • Using the Phillips # PH00 screwdriver unscrew the four 7.1mm screws in the black circle base.
    • Remove the entire black circle base and flip it over so you can see the motherboard.
  5. Carrera Mario Copter Motherboard  Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using tweezers remove the four white heads wires from the motherboard.
    • Be careful not to cut the wires plugged to the little white heads. Grab onto the plastic connectors if possible.
  6. Carrera Mario Copter Motherboard  Replacement: 6 단계, 이미지 1/2 Carrera Mario Copter Motherboard  Replacement: 6 단계, 이미지 2/2
    • Using the tweezers remove the golden head screws that hold down the motherboard.
    • Hold strong the motherboard and pull up strong the head screws.
    • Be careful not to hurt yourself. You will need to try several times to remove those.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Stephany Martinez
회원 가입일: 10/23/17
122 평판
안내서 1개 작성함
UW Tacoma, Team S1-G6, Rose Fall 2017 UW Tacoma, Team S1-G6, Rose Fall 2017 회원
UWT-ROSE-F17S1G6
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 12
전체 시간: 335
