소개
The quadrocopter will not fly correctly if a rotor blade is damaged or installed wrong. This guide will show you how to remove any of the quadrocopter’s four rotor blades.
필요한 것
Using the JIS #00 screwdriver, hold the rotor blade still and unscrew the 4.762mm screw in the center of the blade.
거의 끝나갑니다!
결론
