주요 콘텐츠로 건너뛰기
Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement
필요한 것
  1. Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement, Axle Replacement Guide: 1 단계, 이미지 1/1
    • Flip the car with the bottom side facing up.
    • Using a Philips screwdriver, remove the middle screw on the front axle while holding it the axle in place.
    • Carefully place the screw in a magnetic pad (or somewhere you won’t loose)
  2. Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement: 2 단계, 이미지 1/1
    • Place the new axle where on the curved side is pointed towards center.
    • Screw it into place but make sure it isn't too tight. The axle needs to able to move a bit.
  3. Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement: 3 단계, 이미지 1/1
    • Repeat the same steps for the back axle of the car but without concern of the curved part.
  4. Carrera Mario Kart 8 Peach Axle Replacement Guide Replacement: 4 단계, 이미지 1/1
    • Place the new wheel into the car and attach the new screw
결론
Kimberly Santos
회원 가입일: 09/25/17
331 평판
안내서 3개 작성하였습니다
USF Tampa, Team S3-G5, Cannon Fall 2017 USF Tampa, Team S3-G5, Cannon Fall 2017 회원
USFT-CANNON-F17S3G5
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 15
전체 시간: 804
