주요 콘텐츠로 건너뛰기
Casablanca Intelli-Touch W-11 control testing
필요한 것
  1. Casablanca Intelli-Touch W-11 control testing, Test wiring: 1 단계, 이미지 1개 중 1개
    • Connect the hot side of an AC power cord to the Line In to the W-11
    • Connect the neutral side to a light bulb, lamp, etc.
    • Connect the Line Out of the WC-11 to the other side of the light bulb. Use a jumper wire.
    • Connect the oscilloscope leads to the hot and neutral sides of the light bulb.
    • Be sure that all the wiring is secure so that nothing shorts out during the testing.
    • Plug in the AC plug to a 110 volt outlet
  2. Casablanca Intelli-Touch W-11 control testing, Power test: 2 단계, 이미지 1개 중 1개
    • Turn on the W-11 power switch.
    • Does the light turn on? If not, check your wiring.
    • Turn off the power, take apart the W-11 and test the power switch with a continuity tester/multimeter.
    • Set up the oscilloscope to observe the AC sine wave.
  3. Casablanca Intelli-Touch W-11 control testing, Test the light button: 3 단계, 이미지 1개 중 1개
    • Press the Light button
    • Check the ossilloscope.
    • Do you see the small signal that appears on the rising side of the AC sine wave?
  4. Casablanca Intelli-Touch W-11 control testing, Test the fan button: 4 단계, 이미지 1개 중 1개
    • Press the fan button
    • Do you see the signal on the falling side of the AC sine wave?
  5. Casablanca Intelli-Touch W-11 control testing, Test both switches: 5 단계, 이미지 1개 중 1개
    • Press the fan and light switches simultaneously.
    • Do you see the signals on both the rising and falling sides of the AC sine wave?
결승점
작성자
1다른 기여자 명과 함께
Wayne Seltzer
회원 가입일: 11/09/10
1,841 평판
안내서 10개를 작성함
Global Fixers Global Fixers 회원
Community
56 회원들
안내서 422개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 49
전체 시간: 1,285
