주요 콘텐츠로 건너뛰기
Casdon Dyson Ball Air Cylinder Motor Replacement
필요한 것
  1. Casdon Dyson Ball Air Cylinder Motor Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Casdon Dyson Ball Air Cylinder Motor Replacement: 2 단계, 이미지 1개 중 1개
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
  3. Casdon Dyson Ball Air Cylinder Motor Replacement, Casdon Dyson Ball Disassembly: 3 단계, 이미지 1개 중 1개
    • Remove all seven 9.2mm (0.32 in) screws on the back of the vacuum.
  4. Casdon Dyson Ball Air Cylinder Motor Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the front side covers by pulling them away from the vacuum.
  5. Casdon Dyson Ball Air Cylinder Motor Replacement: 5 단계, 이미지 1개 중 1개
    • Separate the battery compartment from the ball and bead cylinder by sliding the vacuum ball away from the battery compartment.
  6. Casdon Dyson Ball Air Cylinder Motor Replacement: 6 단계, 이미지 1개 중 1개
    • Separate the bead cylinder and the fan compartment by pulling the bead cylinder away from the fan compartment.
  7. Casdon Dyson Ball Air Cylinder Motor Replacement: 7 단계, 이미지 1개 중 1개
    • Remove beads from the container.
  8. Casdon Dyson Ball Air Cylinder Motor Replacement, Air Cylinder Motor: 8 단계, 이미지 1개 중 1개
    • Remove four 9.2mm (0.32 in) screws on bottom of air cylinder motor mount using the PH00 screwdriver.
  9. Casdon Dyson Ball Air Cylinder Motor Replacement: 9 단계, 이미지 1개 중 1개
    • Remove one 11.5mm (0.45 in) screw in battery compartment using the PH00 screwdriver.
  10. Casdon Dyson Ball Air Cylinder Motor Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the red fan from the motor by pulling the red fan away from the bead cylinder motor compartment.
  11. Casdon Dyson Ball Air Cylinder Motor Replacement: 11 단계, 이미지 1개 중 1개
    • Cut wires connected to faulty motor using a set of wire cutters.
  12. Casdon Dyson Ball Air Cylinder Motor Replacement: 12 단계, 이미지 2개 중 1개 Casdon Dyson Ball Air Cylinder Motor Replacement: 12 단계, 이미지 2개 중 2개
    • Remove and replace faulty air cylinder motor.
    • Solder new air cylinder motor's wires to the vacuum's wires which were previously cut.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Seldon Price
회원 가입일: 11/07/17
612 평판
안내서 5개를 작성함
IUPUI, Team S3-G5, Harley Fall 2017 IUPUI, Team S3-G5, Harley Fall 2017 회원
IUPUI-HARLEY-F17S3G5
3 회원들
안내서 10개를 작성함
1가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 15
전체 시간: 495
