주요 콘텐츠로 건너뛰기
Casdon Dyson Ball On/Off Switch Replacement
필요한 것
  1. Casdon Dyson Ball On/Off Switch Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Casdon Dyson Ball On/Off Switch Replacement: 2 단계, 이미지 1개 중 1개
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
  3. Casdon Dyson Ball On/Off Switch Replacement, On/Off Switch: 3 단계, 이미지 1개 중 1개
    • Remove four 9.2mm (0.32 in) screws from the back of the vacuum using the PH00 screwdriver.
  4. Casdon Dyson Ball On/Off Switch Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the cover to the on/off switch by pulling up on the cover from the front of the vacuum.
  5. Casdon Dyson Ball On/Off Switch Replacement: 5 단계, 이미지 1개 중 1개
    • Cut the two wires connected to the on/off switch using a set of wire cutters.
  6. Casdon Dyson Ball On/Off Switch Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the two 9.2mm (0.32 in) screws which hold the on/off switch to the vacuum using the PH00 screwdriver.
  7. Casdon Dyson Ball On/Off Switch Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the on/off switch by pulling it away from the vacuum with your fingers.
    • Replace the faulty on/off switch with the new on/off switch.
    • Solder the new on/off switch's wires to the vacuum's wires using a soldering station.
결론
작성자
1다른 기여자 명과 함께
Seldon Price
회원 가입일: 11/07/17
612 평판
안내서 5개를 작성함
IUPUI, Team S3-G5, Harley Fall 2017 IUPUI, Team S3-G5, Harley Fall 2017 회원
IUPUI-HARLEY-F17S3G5
3 회원들
안내서 10개를 작성함
1가이드 댓글
Great instructions but where can you purchase the on of switch and what is the part number?
debbyh1024 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 17
전체 시간: 2,368
