주요 콘텐츠로 건너뛰기
Casio A1000 Battery Replacement
필요한 것
  1. Casio A1000 Battery Replacement, Battery: 1 단계, 이미지 1/2 Casio A1000 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Press down on the spring with your index finger to detach the wristband.
  2. Casio A1000 Battery Replacement: 2 단계, 이미지 1/2 Casio A1000 Battery Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #000 screwdriver to remove the four screws from the back side of the watch.
    • Keep your parts in one place so that you do not lose them.
  3. Casio A1000 Battery Replacement: 3 단계, 이미지 1/2 Casio A1000 Battery Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Carefully remove the sticker that covers the battery with tweezers.
    • Be careful of your fingers because the ends of the tweezers are sharp.
  4. Casio A1000 Battery Replacement: 4 단계, 이미지 1/3 Casio A1000 Battery Replacement: 4 단계, 이미지 2/3 Casio A1000 Battery Replacement: 4 단계, 이미지 3/3
    • Unhook the lever that holds the battery with tweezers.
    • Carefully remove the dead battery.
  5. Casio A1000 Battery Replacement: 5 단계, 이미지 1/2 Casio A1000 Battery Replacement: 5 단계, 이미지 2/2
    • Insert the new battery into the watch and engage the lever.
    • With your tweezers, reset the AC battery by contacting both the (+) and (AC) points at the same time
  6. Casio A1000 Battery Replacement: 6 단계, 이미지 1/1
    • To reset the watch time:
    • Press the bottom left button to switch mode.
    • Press the bottom right button to reset the number to zero and adjust time.
    • Press the top left button to switch between the hour, minute, and second hand.
결론
Thank you for following our simple guide to replacing your Casio A1000 watch battery. We hope that you will be able to use your watch again!
다른 한 분이 해당 안내서를 완성하였습니다.
Steven Trinh
회원 가입일: 01/31/23
157 평판
안내서 1개 작성함
UC Davis, Team 3-4, Andersen Winter 2023 UC Davis, Team 3-4, Andersen Winter 2023 회원
UCD-ANDERSEN-W23S3G4
3 회원들
안내서 1개 작성하였습니다
댓글 2개
Thank you. This helped convince my son to purchase a Casio A1000 instead of more expensive alternative; the other, as I pointed out, would involve battery replacement that would be more involved, require tools probably not available to him in his location, and likely end up being beyond his pay grade regardless. Casio, on the other hand, allows the KISS method. Much better bang for the buck here. You're the Man!
LongLostAlaskan - 답글
Great. Can you write about what number screws are in this Casio? I can't find it anywhere and I lost 2 and need to buy some more. Unfortunately I don't know what exactly to look for. I will be very grateful for information.
Remigiusz Kurtz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 21
30일 전: 68
전체 시간: 800
