주요 콘텐츠로 건너뛰기
Casio A158WA-1 Watch Circuit Board Replacement
필요한 것
  1. Casio A158WA-1 Watch Circuit Board Replacement, Circuit Board: 1 단계, 이미지 1개 중 1개
    • Remove the four screws from the back of the watch using a Phillips #00 screwdriver.
  2. Casio A158WA-1 Watch Circuit Board Replacement: 2 단계, 이미지 2개 중 1개 Casio A158WA-1 Watch Circuit Board Replacement: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the back cover and the black rubber band with tweezers.
  3. Casio A158WA-1 Watch Circuit Board Replacement: 3 단계, 이미지 2개 중 1개 Casio A158WA-1 Watch Circuit Board Replacement: 3 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to pull the small metal tab and remove the interior of the watch.
  4. Casio A158WA-1 Watch Circuit Board Replacement: 4 단계, 이미지 2개 중 1개 Casio A158WA-1 Watch Circuit Board Replacement: 4 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to lift the metal clasps at each corner and remove the battery holder.
  5. Casio A158WA-1 Watch Circuit Board Replacement: 5 단계, 이미지 1개 중 1개
    • Separate the LCD from the circuit board.
  6. Casio A158WA-1 Watch Circuit Board Replacement: 6 단계, 이미지 1개 중 1개
    • Remember the position of the battery for reassembly.
    • Detach the battery from the circuit board.
  7. Casio A158WA-1 Watch Circuit Board Replacement: 7 단계, 이미지 1개 중 1개
    • Attach the battery to the new circuit board.
  8. Casio A158WA-1 Watch Circuit Board Replacement: 8 단계, 이미지 3개 중 1개 Casio A158WA-1 Watch Circuit Board Replacement: 8 단계, 이미지 3개 중 2개 Casio A158WA-1 Watch Circuit Board Replacement: 8 단계, 이미지 3개 중 3개
    • Place the new circuit board behind the LCD.
  9. Casio A158WA-1 Watch Circuit Board Replacement: 9 단계, 이미지 2개 중 1개 Casio A158WA-1 Watch Circuit Board Replacement: 9 단계, 이미지 2개 중 2개
    • Reattach the battery holder and push down on the clasps at each corner.
  10. Casio A158WA-1 Watch Circuit Board Replacement: 10 단계, 이미지 3개 중 1개 Casio A158WA-1 Watch Circuit Board Replacement: 10 단계, 이미지 3개 중 2개 Casio A158WA-1 Watch Circuit Board Replacement: 10 단계, 이미지 3개 중 3개
    • Place the interior of the watch inside of the shell.
    • Put the rubber band and the lid back in their original position.
결승점
작성자
3다른 기여자 명과 함께
Valeria Pérez Irizarry
회원 가입일: 10/06/21
189 평판
안내서 1개를 작성함
1가이드 댓글
Hi! I believe I have this problem with my Casio royal. Where do you buy the replacements?
Bernardo Rabitti - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 64
전체 시간: 2,159
