이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Flip the keyboard over so that the bottom is facing up.
Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
Flip open the top half of the keyboard.
Set the keyboard onto the bottom half with the internal parts facing up.
Plug in the soldering iron.
Unscrew the top green circuit board with black and red wires running through it.
Heat up the solder covering the end of the wires connected to the circuit board.
Once the solder melts, remove the wires from the circuit board.
Melt new solder with your soldering iron.
Then apply it over the tip of the wire resting on the circuit board.
Once the wires are firmly attached, screw the circuit board back into the keyboard.
다른 3명이 해당 안내서를 완성하였습니다.
