주요 콘텐츠로 건너뛰기
Casio CTK-501 Keys Replacement
필요한 것
  1. Casio CTK-501 Keys Replacement, Bottom Panel: 1 단계, 이미지 2개 중 1개 Casio CTK-501 Keys Replacement, Bottom Panel: 1 단계, 이미지 2개 중 2개
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 Keys Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 Keys Replacement: 3 단계, 이미지 2개 중 1개 Casio CTK-501 Keys Replacement: 3 단계, 이미지 2개 중 2개
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 Keys Replacement, Keys: 4 단계, 이미지 1개 중 1개
    • Completely unscrew and remove the screws holding the broken string of keys in place.
  5. Casio CTK-501 Keys Replacement: 5 단계, 이미지 1개 중 1개
    • Pull up the top layer of white keys to remove them from the keyboard.
  6. Casio CTK-501 Keys Replacement: 6 단계, 이미지 1개 중 1개
    • Pull up on the last layer of white keys to remove them.
  7. Casio CTK-501 Keys Replacement: 7 단계, 이미지 1개 중 1개
    • Push the black keys toward the front of the keyboard and rotate them until they fall out of the keyboard.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jimmy Winne
회원 가입일: 10/04/12
578 평판
안내서 6개를 작성함
Cal Poly, Team 9-16, Amido Fall 2012 Cal Poly, Team 9-16, Amido Fall 2012 회원
CPSU-AMIDO-F12S9G16
4 회원들
안내서 6개를 작성함
4가이드 댓글
my ctk710 keybord circuit failure.... how to get new circuit in online plg help me
michael Akhil - 답글
Please do you know where to get Casio CTK700/720 (or compatible) complete Keys set replacement?
Thanks in advance!
Fred from Brasil
Luis Frederico - 답글
pliskers@optonline.net
Will replacing keys cure a rattle/chatter that I hear from my middle C and D keys when they are played?
pliskers - 답글
I want to repair my Roland Ex 20 keyboard keys because my middle position two keys are muted.
Jit Ghosh - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 31
전체 시간: 25,875
