주요 콘텐츠로 건너뛰기
Casio CTK-501 LCD Screen Replacement
필요한 것
  1. Casio CTK-501 LCD Screen Replacement, Bottom Panel: 1 단계, 이미지 2개 중 1개 Casio CTK-501 LCD Screen Replacement, Bottom Panel: 1 단계, 이미지 2개 중 2개
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 LCD Screen Replacement: 3 단계, 이미지 2개 중 1개 Casio CTK-501 LCD Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 LCD Screen Replacement, LCD Screen: 4 단계, 이미지 1개 중 1개
    • Completely unscrew and remove all six of the screws on the central circuit board.
  5. Casio CTK-501 LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the circuit board out of your way.
  6. Casio CTK-501 LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Remove tape from the LCD screen and remove the screen completely.
  7. Casio CTK-501 LCD Screen Replacement: 7 단계, 이미지 2개 중 1개 Casio CTK-501 LCD Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Replace the LCD screen and tape it down to the top cover.
  8. Casio CTK-501 LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Place the circuit board back on top of the LCD screen.
    • Screw all of the screws completely in their original positions.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Jimmy Winne
회원 가입일: 10/04/12
578 평판
안내서 6개를 작성함
Cal Poly, Team 9-16, Amido Fall 2012 Cal Poly, Team 9-16, Amido Fall 2012 회원
CPSU-AMIDO-F12S9G16
4 회원들
안내서 6개를 작성함
3가이드 댓글
Where did you get the replacement LCD screen? I'm looking for one for my CTK-573 keyboard mbuseck1@yahoo.com
mbuseck1 - 답글
Hi. Would this screen work for CTK 481?
José Saldaña - 답글
hi. I have the ctk 4300. i would like to know where i can get one.Binitintimo@gmail.com
timo binitin - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 32
전체 시간: 5,493
