주요 콘텐츠로 건너뛰기
Casio CTK-501 Speaker Replacement
필요한 것
  1. Casio CTK-501 Speaker Replacement, Bottom Panel: 1 단계, 이미지 2개 중 1개 Casio CTK-501 Speaker Replacement, Bottom Panel: 1 단계, 이미지 2개 중 2개
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 Speaker Replacement: 3 단계, 이미지 2개 중 1개 Casio CTK-501 Speaker Replacement: 3 단계, 이미지 2개 중 2개
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 Speaker Replacement, Speaker: 4 단계, 이미지 1개 중 1개
    • Plug in the soldering iron and place somewhere safe to avoid burning yourself or causing a fire.
    • Completely unscrew and remove all four screws in the corners of the speaker.
  5. Casio CTK-501 Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • Pull the speaker out of the keyboard and set on a flat surface to solder safely.
  6. Casio CTK-501 Speaker Replacement: 6 단계, 이미지 1개 중 1개
    • Be careful when removing the wires and avoid dripping solder on yourself or the keyboard.
    • Touch soldering iron to solder over the end of the wires, and when the solder melts, pull the wires away from the speaker.
    • Remove the speaker and replace with a new one.
  7. Casio CTK-501 Speaker Replacement: 7 단계, 이미지 1개 중 1개
    • Strip the wires if you need more clean metal to solder to the speaker.
    • Use the soldering iron to melt the solder over the wire to connect them to the speaker.
  8. Casio CTK-501 Speaker Replacement: 8 단계, 이미지 1개 중 1개
    • Completely screw in the screws back into the original positions on the corner of the speaker.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jimmy Winne
회원 가입일: 10/04/12
578 평판
안내서 6개를 작성함
Cal Poly, Team 9-16, Amido Fall 2012 Cal Poly, Team 9-16, Amido Fall 2012 회원
CPSU-AMIDO-F12S9G16
4 회원들
안내서 6개를 작성함
1가이드 댓글
I have a Casio ctk 691 Keyboard and it’s not Turning up is working is coming on but my volume slider is not working
Jacameron Bussey - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 29
전체 시간: 6,816
