주요 콘텐츠로 건너뛰기
Casio Cassiopeia E-125 Key Pad Replacement
필요한 것
  1. Casio Cassiopeia E-125 Key Pad Replacement, Battery: 1 단계, 이미지 1/1
    • Flip the device over to the back side.
  2. Casio Cassiopeia E-125 Key Pad Replacement: 2 단계, 이미지 1/1
    • Slide the small switch on the back to "MAIN".
  3. Casio Cassiopeia E-125 Key Pad Replacement: 3 단계, 이미지 1/1
    • Slide the battery cover downwards.
    • Pull off the battery cover.
  4. Casio Cassiopeia E-125 Key Pad Replacement: 4 단계, 이미지 1/1
    • Pull the black tab to remove the battery.
  5. Casio Cassiopeia E-125 Key Pad Replacement, Touch Screen: 5 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the two screws near the top of the device.
  6. Casio Cassiopeia E-125 Key Pad Replacement: 6 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the two screws located inside the battery compartment.
  7. Casio Cassiopeia E-125 Key Pad Replacement: 7 단계, 이미지 1/1
    • Use a spudger or opening tool to separate the two halves of the case.
  8. Casio Cassiopeia E-125 Key Pad Replacement: 8 단계, 이미지 1/1
    • Pry the two halves of the case apart with the opening tool.
  9. Casio Cassiopeia E-125 Key Pad Replacement: 9 단계, 이미지 1/1
    • Potential for device damage. Do not pull apart the wires connecting the outer case.
    • Lay the two halves of the outer case next to the central components as shown.
  10. Casio Cassiopeia E-125 Key Pad Replacement: 10 단계, 이미지 1/1
    • Use the Philips #00 screwdriver to remove the three screws in the corners of the screen.
  11. Casio Cassiopeia E-125 Key Pad Replacement: 11 단계, 이미지 1/2 Casio Cassiopeia E-125 Key Pad Replacement: 11 단계, 이미지 2/2
    • Lift the tab on the motherboard and pull out the ribbon cable.
    • After the ribbon cable is detached from the motherboard, the touch screen is completely separated from the device.
  12. Casio Cassiopeia E-125 Key Pad Replacement, Key Pad: 12 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver and remove the five screws from the daughterboard.
  13. Casio Cassiopeia E-125 Key Pad Replacement: 13 단계, 이미지 1/1
    • Pull the ribbon cable out of its port on the back of the keypad.
  14. Casio Cassiopeia E-125 Key Pad Replacement: 14 단계, 이미지 1/1
    • Now, lift the keypad off the front case.
결론
Ryan Fernandez
회원 가입일: 04/03/12
47 평판
안내서 5개 작성하였습니다
Cal Poly, Team 5-4, Forte Spring 2012 Cal Poly, Team 5-4, Forte Spring 2012 회원
CPSU-FORTE-S12S5G4
6 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 16
전체 시간: 631
