주요 콘텐츠로 건너뛰기
Casio Exilim EX Z55 LCD Screen Replacement
필요한 것
  1. Casio Exilim EX Z55 LCD Screen Replacement, Front Case: 1 단계, 이미지 3개 중 1개 Casio Exilim EX Z55 LCD Screen Replacement, Front Case: 1 단계, 이미지 3개 중 2개 Casio Exilim EX Z55 LCD Screen Replacement, Front Case: 1 단계, 이미지 3개 중 3개
    • Remove eight 1.8 mm screws from the left and right sides of the camera using a Phillips #00 screwdriver
  2. Casio Exilim EX Z55 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the four 3.7 mm screws from the bottom of the camera using a Phillips #00 screwdriver.
  3. Casio Exilim EX Z55 LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Separate the front case from the body of the camera.
  4. Casio Exilim EX Z55 LCD Screen Replacement, Back Case: 4 단계, 이미지 1개 중 1개
    • Separate the back case from the body of the camera.
  5. Casio Exilim EX Z55 LCD Screen Replacement, LCD Screen: 5 단계, 이미지 3개 중 1개 Casio Exilim EX Z55 LCD Screen Replacement, LCD Screen: 5 단계, 이미지 3개 중 2개 Casio Exilim EX Z55 LCD Screen Replacement, LCD Screen: 5 단계, 이미지 3개 중 3개
    • Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up.
  6. Casio Exilim EX Z55 LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Before removing the side metal bracket, first remove the attached strap knob by twisting it off.
    • Then, remove the side metal bracket by inserting the plastic opening tool under the bracket and pulling up.
  7. Casio Exilim EX Z55 LCD Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, pry up the LCD screen starting at one of the corners. Insert the tool under one of the corners and lift up.
  8. Casio Exilim EX Z55 LCD Screen Replacement: 8 단계, 이미지 2개 중 1개 Casio Exilim EX Z55 LCD Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Continue to lift the LCD screen all the way up.
    • Be careful not to rip any wires connecting the LCD screen to the top of the camera.
결론
작성자
8다른 기여자 명과 함께
Laura
회원 가입일: 04/19/12
46 평판
안내서 2개를 작성함
Cal Poly, Team 9-45, Regan Spring 2012 Cal Poly, Team 9-45, Regan Spring 2012 회원
CPSU-REGAN-S12S9G45
7 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 26
전체 시간: 2,191
