주요 콘텐츠로 건너뛰기
Casio Exilim EX Z55 Lens Replacement
필요한 것
  1. Casio Exilim EX Z55 Lens Replacement, Front Case: 1 단계, 이미지 1/3 Casio Exilim EX Z55 Lens Replacement, Front Case: 1 단계, 이미지 2/3 Casio Exilim EX Z55 Lens Replacement, Front Case: 1 단계, 이미지 3/3
    • Remove eight 1.8 mm screws from the left and right sides of the camera using a Phillips #00 screwdriver
  2. Casio Exilim EX Z55 Lens Replacement: 2 단계, 이미지 1/1
    • Remove the four 3.7 mm screws from the bottom of the camera using a Phillips #00 screwdriver.
  3. Casio Exilim EX Z55 Lens Replacement: 3 단계, 이미지 1/1
    • Separate the front case from the body of the camera.
  4. Casio Exilim EX Z55 Lens Replacement, Back Case: 4 단계, 이미지 1/1
    • Separate the back case from the body of the camera.
  5. Casio Exilim EX Z55 Lens Replacement, LCD Screen: 5 단계, 이미지 1/3 Casio Exilim EX Z55 Lens Replacement, LCD Screen: 5 단계, 이미지 2/3 Casio Exilim EX Z55 Lens Replacement, LCD Screen: 5 단계, 이미지 3/3
    • Remove the metal grating located to the right of the LCD screen by inserting the plastic opening tool under the grating and pulling up.
  6. Casio Exilim EX Z55 Lens Replacement: 6 단계, 이미지 1/1
    • Before removing the side metal bracket, first remove the attached strap knob by twisting it off.
    • Then, remove the side metal bracket by inserting the plastic opening tool under the bracket and pulling up.
  7. Casio Exilim EX Z55 Lens Replacement: 7 단계, 이미지 1/1
    • Using the plastic opening tool, pry up the LCD screen starting at one of the corners. Insert the tool under one of the corners and lift up.
  8. Casio Exilim EX Z55 Lens Replacement: 8 단계, 이미지 1/2 Casio Exilim EX Z55 Lens Replacement: 8 단계, 이미지 2/2
    • Continue to lift the LCD screen all the way up.
    • Be careful not to rip any wires connecting the LCD screen to the top of the camera.
  9. Casio Exilim EX Z55 Lens Replacement, Lens: 9 단계, 이미지 1/2 Casio Exilim EX Z55 Lens Replacement, Lens: 9 단계, 이미지 2/2
    • Remove the orange ribbon cable by grabbing the white tab and pulling back.
  10. Casio Exilim EX Z55 Lens Replacement: 10 단계, 이미지 1/2 Casio Exilim EX Z55 Lens Replacement: 10 단계, 이미지 2/2
    • Remove the two 1.66mm screws on both the bottom and top metal plates, using a #00 Phillips screwdriver.
  11. Casio Exilim EX Z55 Lens Replacement: 11 단계, 이미지 1/1
    • Using the plastic opening tool, pry the battery case clamps (located on front of the camera) so that the bottom portion of the camera will come loose.
  12. Casio Exilim EX Z55 Lens Replacement: 12 단계, 이미지 1/1
    • Once the bottom portion of the camera is removed, stand the camera upright, bottom portion facing up, then detach the inner orange strip from the motherboard to the lens by inserting the plastic opening tool under the tab and lifting up.
  13. Casio Exilim EX Z55 Lens Replacement: 13 단계, 이미지 1/1
    • Fully remove the lens from the motherboard.
    • It will still be attached by wires and a different orange ribbon cable.
    • You can now proceed to repair the existing lens or replace it with a new lens.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Greg Bucher
회원 가입일: 04/19/12
14 평판
안내서 1개 작성함
Cal Poly, Team 9-45, Regan Spring 2012 Cal Poly, Team 9-45, Regan Spring 2012 회원
CPSU-REGAN-S12S9G45
7 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 1,443
