주요 콘텐츠로 건너뛰기
Casio Exilim EX-Z70 Battery Replacement
  1. Casio Exilim EX-Z70 Battery Replacement, Battery: 1 단계, 이미지 1/3 Casio Exilim EX-Z70 Battery Replacement, Battery: 1 단계, 이미지 2/3 Casio Exilim EX-Z70 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Orient the camera with the lens facing to the right and the bottom of the camera facing up towards you.
    • Grasping the camera tightly, press downward firmly on the piece with the label and slide it to the left (towards the LCD screen).
    • The flap will then swing upward.
  2. Casio Exilim EX-Z70 Battery Replacement: 2 단계, 이미지 1/2 Casio Exilim EX-Z70 Battery Replacement: 2 단계, 이미지 2/2
    • With the battery now exposed, pull the dark gray tab away from the battery.
    • The battery is no longer secured in the camera.
  3. Casio Exilim EX-Z70 Battery Replacement: 3 단계, 이미지 1/1
    • Firmly grasp each side of the battery and pull it out of its compartment.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jenn Eberts
회원 가입일: 04/10/12
277 평판
안내서 1개 작성함
Cal Poly, Team 17-28, Amido Spring 2012 Cal Poly, Team 17-28, Amido Spring 2012 회원
CPSU-AMIDO-S12S17G28
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 15
30일 전: 62
전체 시간: 4,937
