부품
부품은 필요하지 않습니다.
  • Open the battery door by sliding it toward the LCD screen.
  • This will reveal a small screw to the left of the memory card slot.
  • Carefully remove the screw (1.77mm).
  • The bottom panel of the camera will become loose. It is connected to the camera by two wires so do not remove completely.
댓글 쓰기
We have oriented the camera with the lens up and the flash toward you for clear visibility. Use a pair of tweezers to gently move the red and black wires away from the lens.
  • We have oriented the camera with the lens up and the flash toward you for clear visibility.
  • Use a pair of tweezers to gently move the red and black wires away from the lens.
댓글 쓰기
아버지의 날 선물 안내
아버지 뿐만 아니라 다른 분들도 존중합시다—우리에게 수리하는 법을 가르쳐 주신 모든 멘토를 축하합시다.
아버지의 날 선물 안내
우리에게 수리하는 법을 가르쳐 주신 사람들을 존중합시다.
Using tweezers or finger nails to pull up the brown flaps where the three orange film strips meets the circuit board. Use tweezers to pull the orange film strips out of each port. Be sure to do this to all three orange strips. They should come out easily. Use tweezers to pull the orange film strips out of each port. Be sure to do this to all three orange strips. They should come out easily.
  • Using tweezers or finger nails to pull up the brown flaps where the three orange film strips meets the circuit board.
  • Use tweezers to pull the orange film strips out of each port. Be sure to do this to all three orange strips. They should come out easily.
댓글 쓰기
  • Pull the circuit board away from the camera.
  • Be careful the circuit board is still attached to the camera by a black film strip.
댓글 쓰기
  • Gently pull off the plastic cover over the LCD screen
댓글 쓰기
  • Gently pull the LCD screen away from the camera. Be careful since the screen is still attached to the camera circuit board.
  • You have now completed the guide to remove the the LCD screen.
댓글 쓰기
결론
Jenn Eberts
회원 가입일: 2012년 04월 10일
200 평판
안내서 2개 작성하였습니다
Cal Poly, Team 17-28, Amido Spring 2012 Cal Poly, Team 17-28, Amido Spring 2012 회원
CPSU-AMIDO-S12S17G28
4 회원들
안내서 9개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 286
