주요 콘텐츠로 건너뛰기
Casio Exilim EX-Z80 Back and Front Cover Replacement
필요한 것
  1. Casio Exilim EX-Z80 Back and Front Cover Replacement, Battery: 1 단계, 이미지 2개 중 1개 Casio Exilim EX-Z80 Back and Front Cover Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Locate the battery compartment at the bottom of the camera.
    • With your thumb, gently press down on the compartment door and slide to the left to open.
  2. Casio Exilim EX-Z80 Back and Front Cover Replacement: 2 단계, 이미지 2개 중 1개 Casio Exilim EX-Z80 Back and Front Cover Replacement: 2 단계, 이미지 2개 중 2개
    • With your index finger, gently pull back gray release lever for the battery to pop out.
    • Gently pull the battery out of the slot.
  3. Casio Exilim EX-Z80 Back and Front Cover Replacement, Back and Front Cover: 3 단계, 이미지 3개 중 1개 Casio Exilim EX-Z80 Back and Front Cover Replacement, Back and Front Cover: 3 단계, 이미지 3개 중 2개 Casio Exilim EX-Z80 Back and Front Cover Replacement, Back and Front Cover: 3 단계, 이미지 3개 중 3개
    • Remove the four 3 mm black screws from the bottom of the camera using a Phillips #000 screwdriver.
    • Open the battery compartment with your thumb or index finger.
    • Remove the single 2 mm silver screw that is now exposed using a Phillips #000 screwdriver.
  4. Casio Exilim EX-Z80 Back and Front Cover Replacement: 4 단계, 이미지 3개 중 1개 Casio Exilim EX-Z80 Back and Front Cover Replacement: 4 단계, 이미지 3개 중 2개 Casio Exilim EX-Z80 Back and Front Cover Replacement: 4 단계, 이미지 3개 중 3개
    • Open the USB port tab.
    • Remove the single 2 mm silver screw using a Phillips #000 screwdriver.
  5. Casio Exilim EX-Z80 Back and Front Cover Replacement: 5 단계, 이미지 2개 중 1개 Casio Exilim EX-Z80 Back and Front Cover Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the two 2 mm silver screws using a Phillips #000 screwdriver.
  6. Casio Exilim EX-Z80 Back and Front Cover Replacement: 6 단계, 이미지 2개 중 1개 Casio Exilim EX-Z80 Back and Front Cover Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully remove the silver strip from left side. Open the battery cover and remove the metal strip with fingers by sliding it to the left.
  7. Casio Exilim EX-Z80 Back and Front Cover Replacement: 7 단계, 이미지 2개 중 1개 Casio Exilim EX-Z80 Back and Front Cover Replacement: 7 단계, 이미지 2개 중 2개
    • With the metal spudger, pry out the edge of the silver strip at the bottom right side of the camera.
    • Carefully remove the remaining part of the metal strip.
  8. Casio Exilim EX-Z80 Back and Front Cover Replacement: 8 단계, 이미지 2개 중 1개 Casio Exilim EX-Z80 Back and Front Cover Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the two 2 mm silver screws from the top corners of the camera using a Phillips #000 screwdriver.
    • Remove the three 2 mm screws from the left side using a Phillips #000 screwdriver.
  9. Casio Exilim EX-Z80 Back and Front Cover Replacement: 9 단계, 이미지 3개 중 1개 Casio Exilim EX-Z80 Back and Front Cover Replacement: 9 단계, 이미지 3개 중 2개 Casio Exilim EX-Z80 Back and Front Cover Replacement: 9 단계, 이미지 3개 중 3개
    • Using a small opening tool carefully release all lock tabs at the top and on the side of the camera from their locked position.
    • Using your hands, carefully separate the front and back panel from the camera.
결론
작성자
5다른 기여자 명과 함께
Caroline Villasenor
회원 가입일: 04/11/17
331 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 25
전체 시간: 804
