주요 콘텐츠로 건너뛰기
Casio Exilim EX-Z80 LCD Screen Replacement
필요한 것
  1. Casio Exilim EX-Z80 LCD Screen Replacement, Back and Front Cover: 1 단계, 이미지 1/3 Casio Exilim EX-Z80 LCD Screen Replacement, Back and Front Cover: 1 단계, 이미지 2/3 Casio Exilim EX-Z80 LCD Screen Replacement, Back and Front Cover: 1 단계, 이미지 3/3
    • Remove the four 3 mm black screws from the bottom of the camera using a Phillips #000 screwdriver.
    • Open the battery compartment with your thumb or index finger.
    • Remove the single 2 mm silver screw that is now exposed using a Phillips #000 screwdriver.
  2. Casio Exilim EX-Z80 LCD Screen Replacement: 2 단계, 이미지 1/3 Casio Exilim EX-Z80 LCD Screen Replacement: 2 단계, 이미지 2/3 Casio Exilim EX-Z80 LCD Screen Replacement: 2 단계, 이미지 3/3
    • Open the USB port tab.
    • Remove the single 2 mm silver screw using a Phillips #000 screwdriver.
  3. Casio Exilim EX-Z80 LCD Screen Replacement: 3 단계, 이미지 1/2 Casio Exilim EX-Z80 LCD Screen Replacement: 3 단계, 이미지 2/2
    • Remove the two 2 mm silver screws using a Phillips #000 screwdriver.
  4. Casio Exilim EX-Z80 LCD Screen Replacement: 4 단계, 이미지 1/2 Casio Exilim EX-Z80 LCD Screen Replacement: 4 단계, 이미지 2/2
    • Carefully remove the silver strip from left side. Open the battery cover and remove the metal strip with fingers by sliding it to the left.
  5. Casio Exilim EX-Z80 LCD Screen Replacement: 5 단계, 이미지 1/2 Casio Exilim EX-Z80 LCD Screen Replacement: 5 단계, 이미지 2/2
    • With the metal spudger, pry out the edge of the silver strip at the bottom right side of the camera.
    • Carefully remove the remaining part of the metal strip.
  6. Casio Exilim EX-Z80 LCD Screen Replacement: 6 단계, 이미지 1/2 Casio Exilim EX-Z80 LCD Screen Replacement: 6 단계, 이미지 2/2
    • Remove the two 2 mm silver screws from the top corners of the camera using a Phillips #000 screwdriver.
    • Remove the three 2 mm screws from the left side using a Phillips #000 screwdriver.
  7. Casio Exilim EX-Z80 LCD Screen Replacement: 7 단계, 이미지 1/3 Casio Exilim EX-Z80 LCD Screen Replacement: 7 단계, 이미지 2/3 Casio Exilim EX-Z80 LCD Screen Replacement: 7 단계, 이미지 3/3
    • Using a small opening tool carefully release all lock tabs at the top and on the side of the camera from their locked position.
    • Using your hands, carefully separate the front and back panel from the camera.
  8. Casio Exilim EX-Z80 LCD Screen Replacement, LCD Screen: 8 단계, 이미지 1/3 Casio Exilim EX-Z80 LCD Screen Replacement, LCD Screen: 8 단계, 이미지 2/3 Casio Exilim EX-Z80 LCD Screen Replacement, LCD Screen: 8 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Gently flip the wide button cable up from the display cable.
    • Lift the brown retention flap on the display cable ZIF connector with tweezers or an ESD-safe tool.
    • Carefully pull the display cable from its connector.
  9. Casio Exilim EX-Z80 LCD Screen Replacement: 9 단계, 이미지 1/3 Casio Exilim EX-Z80 LCD Screen Replacement: 9 단계, 이미지 2/3 Casio Exilim EX-Z80 LCD Screen Replacement: 9 단계, 이미지 3/3
    • Pry the square holes that hold the LCD screen up with a metal spudger until you see the raised tabs in the metal holes.
    • Repeat the process with the holes around the four edges of the camera.
    • Insert the metal spudger into the gap of the metal case and pry up the LCD screen.
  10. Casio Exilim EX-Z80 LCD Screen Replacement: 10 단계, 이미지 1/3 Casio Exilim EX-Z80 LCD Screen Replacement: 10 단계, 이미지 2/3 Casio Exilim EX-Z80 LCD Screen Replacement: 10 단계, 이미지 3/3
    • Hold up the LCD screen in one hand and hold back the button cable with the other.
    • Don't let the LCD screen to fall back into the metal case and make sure the button cable does not get stuck on the display cable.
    • Pull on the LCD screen until the yellow display cable is fully out of the metal case.
결론
Zhiliang Peng
회원 가입일: 04/11/17
206 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 21
전체 시간: 399
