주요 콘텐츠로 건너뛰기
Casio Exilim EX-Z850 Flash Assembly Replacement
필요한 것
  1. Casio Exilim EX-Z850 Flash Assembly Replacement, Flash Assembly: 1 단계, 이미지 1개 중 1개
    • With your Phillips #00 screwdriver, remove the four screws on the side of the camera.
  2. Casio Exilim EX-Z850 Flash Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • With a Phillips #00 screwdriver, remove the four screws located on the bottom of the camera.
    • The bottom screws are longer than the top screws, so label accordingly for easy reassembly.
  3. Casio Exilim EX-Z850 Flash Assembly Replacement: 3 단계, 이미지 1개 중 1개
    • With a Phillips #00 screwdriver, remove the four screws on the opposite side of the camera.
  4. Casio Exilim EX-Z850 Flash Assembly Replacement: 4 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 Flash Assembly Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Once all screws have been removed, gently pry open bottom casing.
    • With tweezers, carefully remove the ribbon from the LCD screen.
    • Set bottom casing aside.
    • Prying open the camera from the casing could potentially damage the device, so open the casing slowly.
  5. Casio Exilim EX-Z850 Flash Assembly Replacement: 5 단계, 이미지 3개 중 1개 Casio Exilim EX-Z850 Flash Assembly Replacement: 5 단계, 이미지 3개 중 2개 Casio Exilim EX-Z850 Flash Assembly Replacement: 5 단계, 이미지 3개 중 3개
    • Using tweezers, gently pry apart the top casing from the camera.
    • Set the top casing aside.
  6. Casio Exilim EX-Z850 Flash Assembly Replacement: 6 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 Flash Assembly Replacement: 6 단계, 이미지 2개 중 2개
    • Use tweezers to pry the LCD screen off from the opening.
    • The bottom of the LCD screen is attached to the frame by a few pieces of black tape.
  7. Casio Exilim EX-Z850 Flash Assembly Replacement: 7 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 Flash Assembly Replacement: 7 단계, 이미지 2개 중 2개
    • Use tweezers to lift up the LCD screen away from the camera.
    • Moving the screen could potentially damage the wire connecting it to the camera, so move the LCD screen slowly.
  8. Casio Exilim EX-Z850 Flash Assembly Replacement: 8 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 Flash Assembly Replacement: 8 단계, 이미지 2개 중 2개
    • Use tweezers to slowly pry off LCD casing by lifting and moving it off the camera.
  9. Casio Exilim EX-Z850 Flash Assembly Replacement: 9 단계, 이미지 3개 중 1개 Casio Exilim EX-Z850 Flash Assembly Replacement: 9 단계, 이미지 3개 중 2개 Casio Exilim EX-Z850 Flash Assembly Replacement: 9 단계, 이미지 3개 중 3개
    • Use tweezers to flip open the connector holding the ribbon.
    • Gently pull out the LCD screen with the ribbon from the camera.
  10. Casio Exilim EX-Z850 Flash Assembly Replacement: 10 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 Flash Assembly Replacement: 10 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, remove the two screws on the side where the battery is located.
    • Remove the lanyard loop after the screws come off.
    • Slowly pull the side casing so it becomes dislocated from the top of the camera frame.
  11. Casio Exilim EX-Z850 Flash Assembly Replacement: 11 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 Flash Assembly Replacement: 11 단계, 이미지 2개 중 2개
    • On the front of the camera, detach the ribbon from the connector.
  12. Casio Exilim EX-Z850 Flash Assembly Replacement: 12 단계, 이미지 3개 중 1개 Casio Exilim EX-Z850 Flash Assembly Replacement: 12 단계, 이미지 3개 중 2개 Casio Exilim EX-Z850 Flash Assembly Replacement: 12 단계, 이미지 3개 중 3개
    • Carefully remove the L shaped frame from the camera.
    • There is a yellow and orange wire connected to camera. Be careful not to pull them off.
    • At the bottom of the camera, the L-shaped frame is connected by two plastic bumps and a metal tab.
  13. Casio Exilim EX-Z850 Flash Assembly Replacement: 13 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screwdriver, remove the two screws on the front of the flash assembly.
    • Remove flash assembly, and replace it with a new flash assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Christian
회원 가입일: 01/28/11
320 평판
안내서 3개를 작성함
Cal Poly, Team 4-38, Regan Winter 2011 Cal Poly, Team 4-38, Regan Winter 2011 회원
CPSU-REGAN-W11S4G38
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 3,166
