주요 콘텐츠로 건너뛰기
Casio Exilim EX-Z850 LCD Screen Replacement
필요한 것
  1. Casio Exilim EX-Z850 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1개 중 1개
    • Remove the two screws on the side of the speakers with the Phillips 00 Screwdriver, on the portion of the camera that is a part of the back casing.
    • Label screws (where they came from and what step) and set aside in the sorting tray.
  2. Casio Exilim EX-Z850 LCD Screen Replacement: 2 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 LCD Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the two back screws on the bottom of the camera on the same side as the LCD screen.
    • Note: The bottom screws are longer than the top ones, so label the screws accordingly for ease in reassembly. (See attached picture.)
  3. Casio Exilim EX-Z850 LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the screws on the opposite of the speakers.
    • Label the screws accordingly and add to the sorting tray.
  4. Casio Exilim EX-Z850 LCD Screen Replacement: 4 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 LCD Screen Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Once all screws have been removed, gently pry open the bottom casing.
    • Use the tweezers to carefully remove the ribbon from the LCD screen- NOT from the back casing itself.
    • Set the bottom casing aside.
    • Navigation button may fall out so be cautious of this and set aside if needed.
  5. Casio Exilim EX-Z850 LCD Screen Replacement: 5 단계, 이미지 3개 중 1개 Casio Exilim EX-Z850 LCD Screen Replacement: 5 단계, 이미지 3개 중 2개 Casio Exilim EX-Z850 LCD Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Use the tweezers to pry the LCD screen off from the openings. There are 5 spots that the tweezers can go in to pry the LCD screen off (see attached pictures).
    • There is a ribbon attached to the screen. Be sure not to pull this ribbon off the screen.
  6. Casio Exilim EX-Z850 LCD Screen Replacement: 6 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 LCD Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Use the tweezers to lift up the LCD screen.
    • Grab the LCD screen with the index finger and thumb, leave the ribbon attached to the screen and leave it on the side.
    • Be sure to be very gentle with the LCD screen.
  7. Casio Exilim EX-Z850 LCD Screen Replacement: 7 단계, 이미지 3개 중 1개 Casio Exilim EX-Z850 LCD Screen Replacement: 7 단계, 이미지 3개 중 2개 Casio Exilim EX-Z850 LCD Screen Replacement: 7 단계, 이미지 3개 중 3개
    • Under the LCD screen you will see an LCD casing. You will want to GENTLY pry this off using the tweezers.
    • The casing may possibly be attached to the LCD screen. If so, leave it attached to the screen.
  8. Casio Exilim EX-Z850 LCD Screen Replacement: 8 단계, 이미지 3개 중 1개 Casio Exilim EX-Z850 LCD Screen Replacement: 8 단계, 이미지 3개 중 2개 Casio Exilim EX-Z850 LCD Screen Replacement: 8 단계, 이미지 3개 중 3개
    • Use the tweezers to flip open the connectors holding the ribbon.
    • Pull out the LCD screen with the ribbon from the camera.
    • THIS STEP IS WHEN WHERE YOU SHOULD USE CAUTION AND BE VERY GENTLE!
  9. Casio Exilim EX-Z850 LCD Screen Replacement: 9 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 LCD Screen Replacement: 9 단계, 이미지 2개 중 2개
    • Your LCD screen is now detached.
    • Locate the replacement screen that you will now attach.
  10. Casio Exilim EX-Z850 LCD Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Reconnect the LCD ribbon to the connectors and flip back down.
    • Ribbon should be inserted straight in and to the right side.
  11. Casio Exilim EX-Z850 LCD Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Reattach the LCD casing.
    • Flip it back into place.
  12. Casio Exilim EX-Z850 LCD Screen Replacement: 12 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 LCD Screen Replacement: 12 단계, 이미지 2개 중 2개
    • Make sure the LCD screen is firmly connected to the camera.
    • Slightly push the LCD screen down with one finger until you hear a click.
  13. Casio Exilim EX-Z850 LCD Screen Replacement: 13 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 LCD Screen Replacement: 13 단계, 이미지 2개 중 2개
    • Reattach the back casing as well as the small ribbon with it to the camera body.
    • Be carefully reattaching the case. Using both hands might help.
  14. Casio Exilim EX-Z850 LCD Screen Replacement: 14 단계, 이미지 1개 중 1개
    • Locate the labeled screws from Step 2-on the bottom of the camera.
    • These are the longer screws. Screw them back in.
    • The picture shown does not show the right screw removed and ready to be replaced due to an issue with this specific camera.
  15. Casio Exilim EX-Z850 LCD Screen Replacement: 15 단계, 이미지 3개 중 1개 Casio Exilim EX-Z850 LCD Screen Replacement: 15 단계, 이미지 3개 중 2개 Casio Exilim EX-Z850 LCD Screen Replacement: 15 단계, 이미지 3개 중 3개
    • Locate the labeled screws from Step 1 and Step 3-on the side of the camera.
    • These are the shorter screws. Screw them back in.
    • Congratulations! Your camera has been reassembled.
결론
By now you should have been able to get your Casio Exilim EX-Z850 camera's LCD screen functioning.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Christian
회원 가입일: 01/28/11
320 평판
안내서 3개를 작성함
Cal Poly, Team 4-38, Regan Winter 2011 Cal Poly, Team 4-38, Regan Winter 2011 회원
CPSU-REGAN-W11S4G38
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 27
전체 시간: 3,227
