주요 콘텐츠로 건너뛰기
Casio Exilim EX-Z850 Motherboard Replacement
필요한 것
  1. Casio Exilim EX-Z850 Motherboard Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
    • Using the Phillips #00 screwdriver, remove the four screws from the side of the speaker.
  2. Casio Exilim EX-Z850 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Using the Phillips #00 screwdriver, remove the four long screws from the bottom of the camera.
    • When reassembling the camera, the longer screws go on the bottom of the camera.
  3. Casio Exilim EX-Z850 Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Using the Phillips #00 screwdriver, remove the four screws from the side opposite of the speaker.
  4. Casio Exilim EX-Z850 Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Casio Exilim EX-Z850 Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Casio Exilim EX-Z850 Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Pry open bottom casing gently after all screws have been removed.
    • With tweezers, carefully remove the ribbon from the LCD screen.
    • Set the bottom casing aside.
  5. Casio Exilim EX-Z850 Motherboard Replacement: 5 단계, 이미지 3개 중 1개 Casio Exilim EX-Z850 Motherboard Replacement: 5 단계, 이미지 3개 중 2개 Casio Exilim EX-Z850 Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Pry apart the top casing using tweezers.
    • Set the top casing aside.
    • The bottom left screw on the board is orange and the longest screw.
  6. Casio Exilim EX-Z850 Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully remove the pieces of black tape on the bottom of the LCD screen that attach it to the frame.
    • Use tweezers to pry the LCD screen off from the opening.
  7. Casio Exilim EX-Z850 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Lift the LCD screen and move it to the other side.
  8. Casio Exilim EX-Z850 Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Using a pair of tweezers, pry off the LCD casing.
  9. Casio Exilim EX-Z850 Motherboard Replacement: 9 단계, 이미지 3개 중 1개 Casio Exilim EX-Z850 Motherboard Replacement: 9 단계, 이미지 3개 중 2개 Casio Exilim EX-Z850 Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Flip open the connector holding the ribbon.
    • Use the tweezers to carefully pull out the LCD screen with the ribbon from the camera.
  10. Casio Exilim EX-Z850 Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Using the Phillips #00 screwdriver, remove two screws on the side where the battery is located.
    • Remove the lanyard loop after the screws come off.
    • Pull the side casing so it becomes dislocated from the top of the camera frame.
  11. Casio Exilim EX-Z850 Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 Motherboard Replacement: 11 단계, 이미지 2개 중 2개
    • On the front of the camera near the flash, flip the connector holding the ribbon.
    • Remove the ribbon from the connector.
  12. Casio Exilim EX-Z850 Motherboard Replacement: 12 단계, 이미지 3개 중 1개 Casio Exilim EX-Z850 Motherboard Replacement: 12 단계, 이미지 3개 중 2개 Casio Exilim EX-Z850 Motherboard Replacement: 12 단계, 이미지 3개 중 3개
    • Carefully remove the L-shaped frame from the camera.
    • The L shaped frame is being held in by two plastic bumps and a metal tab at the bottom of the camera.
    • Pop the frame off the bumps and tabs.
    • Potential for device damage: Be careful not to pull off the yellow and orange wire soldered onto the camera.
  13. Casio Exilim EX-Z850 Motherboard Replacement: 13 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 Motherboard Replacement: 13 단계, 이미지 2개 중 2개
    • Flip the connector and remove the ribbon cable from the motherboard next to the lens.
  14. Casio Exilim EX-Z850 Motherboard Replacement: 14 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 Motherboard Replacement: 14 단계, 이미지 2개 중 2개
    • Remove the frame on the back side of the camera where the LCD screen was.
    • Use the Phillips #00 screwdriver to remove the two screws connecting the frame to the camera.
    • Slowly pry off the frame from the camera.
    • After removing the frame, a plastic piece with two yellow buttons should fall off.
    • Do not pull the plastic piece off as it is soldered to two wires: a yellow and orange one.
  15. Casio Exilim EX-Z850 Motherboard Replacement: 15 단계, 이미지 1개 중 1개
    • On the back of the camera where the LCD screen was, remove the 3 screws located behind the lens using the Phillips #00 screwdriver.
  16. Casio Exilim EX-Z850 Motherboard Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the large orange ribbon previously held in by screws from the camera.
  17. Casio Exilim EX-Z850 Motherboard Replacement: 17 단계, 이미지 1개 중 1개
    • On the backside of the camera where the indicator lamp is located, remove the two screws using the Phillips #00 screwdriver.
  18. Casio Exilim EX-Z850 Motherboard Replacement: 18 단계, 이미지 3개 중 1개 Casio Exilim EX-Z850 Motherboard Replacement: 18 단계, 이미지 3개 중 2개 Casio Exilim EX-Z850 Motherboard Replacement: 18 단계, 이미지 3개 중 3개
    • On the front side of the indicator lamp remove the screw using the Phillips #00 screwdriver.
  19. Casio Exilim EX-Z850 Motherboard Replacement: 19 단계, 이미지 2개 중 1개 Casio Exilim EX-Z850 Motherboard Replacement: 19 단계, 이미지 2개 중 2개
    • Desolder the lens from the motherboard.
    • Desolder the wire from the motherboard.
    • The motherboard is now detached from the rest of the camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Jennifer Roth
회원 가입일: 01/28/11
162 평판
안내서 1개를 작성함
Cal Poly, Team 4-38, Regan Winter 2011 Cal Poly, Team 4-38, Regan Winter 2011 회원
CPSU-REGAN-W11S4G38
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 16
전체 시간: 4,120
