주요 콘텐츠로 건너뛰기
Casio Exilim EX-Z850 Outer Case Replacement
필요한 것
  1. Casio Exilim EX-Z850 Outer Case Replacement, Outer Case: 1 단계, 이미지 1/3 Casio Exilim EX-Z850 Outer Case Replacement, Outer Case: 1 단계, 이미지 2/3 Casio Exilim EX-Z850 Outer Case Replacement, Outer Case: 1 단계, 이미지 3/3
    • Remove all four screws on the camera's side using a Phillips #00 screwdriver.
    • Remove all four screws on the opposite side of the camera using the same screwdriver.
    • Remove all four screws on the bottom of the camera using the same screwdriver.
    • The bottom screws are longer than the top screws, so label them accordingly for easy reassembly.
  2. Casio Exilim EX-Z850 Outer Case Replacement: 2 단계, 이미지 1/3 Casio Exilim EX-Z850 Outer Case Replacement: 2 단계, 이미지 2/3 Casio Exilim EX-Z850 Outer Case Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Pry open the bottom casing.
    • Remove the ribbon from the LCD screen using the tweezers and set aside the bottom casing.
    • These steps should be taken carefully in order to prevent damage to the camera.
  3. Casio Exilim EX-Z850 Outer Case Replacement: 3 단계, 이미지 1/2 Casio Exilim EX-Z850 Outer Case Replacement: 3 단계, 이미지 2/2
    • Pry apart the top casing using tweezers.
    • Remove the top casing from the camera and set aside the top casing.
결론
To reassemble your device, follow these instructions in reverse order, starting with reattaching the top casing.
다른 2명이 해당 안내서를 완성하였습니다.
Logan
회원 가입일: 01/10/11
313 평판
안내서 2개 작성하였습니다
Cal Poly, Team 4-38, Regan Winter 2011 Cal Poly, Team 4-38, Regan Winter 2011 회원
CPSU-REGAN-W11S4G38
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 12
전체 시간: 3,065
