주요 콘텐츠로 건너뛰기
Casio FX-115ES PLUS Battery Replacement
필요한 것
  1. Casio FX-115ES PLUS Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off the calculator by pressing the [shift] button.
    • Press the [AC] [OFF] button to turn off the calculator by pressing the [shift] button.
  2. Casio FX-115ES PLUS Battery Replacement: 2 단계, 이미지 3개 중 1개 Casio FX-115ES PLUS Battery Replacement: 2 단계, 이미지 3개 중 2개 Casio FX-115ES PLUS Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Turn the calculator the other way around so that the small panel in the top right corner of the back of the calculator faces forward.
    • Use a Phillips #0 screwdriver to remove the screw in the upper right corner.
    • Don't force the screwdriver on the screw, as it can strip the screw
  3. Casio FX-115ES PLUS Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the battery cover.
  4. Casio FX-115ES PLUS Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Insert the spudger in the available slot in the middle of the right side.
    • Use the spudger to take the battery out carefully.
    • Be careful when removing the battery to avoid any damage.
  5. Casio FX-115ES PLUS Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Place the new 357 oxide button battery into the calculator.
    • Make sure that the + sign is at the bottom.
  6. Casio FX-115ES PLUS Battery Replacement: 6 단계, 이미지 3개 중 1개 Casio FX-115ES PLUS Battery Replacement: 6 단계, 이미지 3개 중 2개 Casio FX-115ES PLUS Battery Replacement: 6 단계, 이미지 3개 중 3개
    • Reattach the battery cover.
    • Insert the screw back in place along with the cover using a Phillips #0 screwdriver.
    • Make sure to turn the screwdriver clockwise to lock the screw in tight, preventing the battery from falling out.
  7. Casio FX-115ES PLUS Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Reset the calculator by pressing [ON].
    • Press the [Shift] button.
    • Press the [9] [CLR] button to clear the data.
    • Press the [3] [ALL] button option.
    • Press the [=] [yes] button to accept.
    • Press the [AC] key to reset completely.
결론
You have successfully replaced a Casio FX-115ES PLUS battery
작성자
1다른 기여자 명과 함께
Rodrigo Lopez
회원 가입일: 01/23/23
145 평판
안내서 1개를 작성함
CSU Los Angeles, Team 2-1, Briggs Spring 2023 CSU Los Angeles, Team 2-1, Briggs Spring 2023 회원
CSULA-BRIGGS-S23S2G1
2 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 89
전체 시간: 3,679
