주요 콘텐츠로 건너뛰기
Casio FX-115MS Battery Replacement
필요한 것
  1. Casio FX-115MS Battery Replacement, Back Plate: 1 단계, 이미지 1/1
    • Remove the 6 screws, which are 5mm long, using a PH1 screwdriver.
  2. Casio FX-115MS Battery Replacement: 2 단계, 이미지 1/3 Casio FX-115MS Battery Replacement: 2 단계, 이미지 2/3 Casio FX-115MS Battery Replacement: 2 단계, 이미지 3/3
    • Use plastic spudger to separate backplate from the front-plate. Place the flat end of the spudger in the seam between the front and back, near one end of the calculator. Then slide the spudger towards the calculator's center. The two sides will pop free from each other as you go through it with the spudger.
  3. Casio FX-115MS Battery Replacement, Battery: 3 단계, 이미지 1/2 Casio FX-115MS Battery Replacement, Battery: 3 단계, 이미지 2/2
    • Using the pointed end of the nylon spudger, carefully pry an edge of the battery, and lift the battery from its socket.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Lindsey Griffin
회원 가입일: 10/04/16
454 평판
안내서 3개 작성하였습니다
USF Tampa, Team 2-2, Nance Fall 2016 USF Tampa, Team 2-2, Nance Fall 2016 회원
USFT-NANCE-F16S2G2
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 21
30일 전: 105
전체 시간: 6,497
