주요 콘텐츠로 건너뛰기
Casio FX-115MS Battery Replacement
필요한 것
  1. Casio FX-115MS Battery Replacement, Back Plate: 1 단계, 이미지 1개 중 1개
    • Remove the 6 screws, which are 5mm long, using a PH1 screwdriver.
  2. Casio FX-115MS Battery Replacement: 2 단계, 이미지 3개 중 1개 Casio FX-115MS Battery Replacement: 2 단계, 이미지 3개 중 2개 Casio FX-115MS Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Use plastic spudger to separate backplate from the front-plate. Place the flat end of the spudger in the seam between the front and back, near one end of the calculator. Then slide the spudger towards the calculator's center. The two sides will pop free from each other as you go through it with the spudger.
  3. Casio FX-115MS Battery Replacement, Battery: 3 단계, 이미지 2개 중 1개 Casio FX-115MS Battery Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Using the pointed end of the nylon spudger, carefully pry an edge of the battery, and lift the battery from its socket.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Lindsey Griffin
회원 가입일: 10/04/16
472 평판
안내서 3개를 작성함
USF Tampa, Team 2-2, Nance Fall 2016 USF Tampa, Team 2-2, Nance Fall 2016 회원
USFT-NANCE-F16S2G2
4 회원들
안내서 15개를 작성함
2가이드 댓글
I just wanted to be sure that using a spudger wouldn't damage anything inside before actually trying it; this quick guide comfirmed it would be OK. However, I found I had to pry from the gap you can open by hand after removing the screws, rather than from the end as suggested in the guide. Maybe it's different for the version with five screws (from about the year 2005), which I have, instead of the illustrated version with six screws.
Andrew Morton - 답글
What size or type of battery does it take? It would be nice to have it on hand before prying it apart. Thanks-
Norman Timbs Jr - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 30
지난 30일: 156
전체 시간: 8,887
