주요 콘텐츠로 건너뛰기
Casio FX-115MS Individual Keys Replacement
필요한 것
  1. Casio FX-115MS Individual Keys Replacement, Back Plate: 1 단계, 이미지 1개 중 1개
    • Remove the 6 screws, which are 5mm long, using a PH1 screwdriver.
  2. Casio FX-115MS Individual Keys Replacement: 2 단계, 이미지 3개 중 1개 Casio FX-115MS Individual Keys Replacement: 2 단계, 이미지 3개 중 2개 Casio FX-115MS Individual Keys Replacement: 2 단계, 이미지 3개 중 3개
    • Use plastic spudger to separate backplate from the front-plate. Place the flat end of the spudger in the seam between the front and back, near one end of the calculator. Then slide the spudger towards the calculator's center. The two sides will pop free from each other as you go through it with the spudger.
  3. Casio FX-115MS Individual Keys Replacement, Battery: 3 단계, 이미지 2개 중 1개 Casio FX-115MS Individual Keys Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Using the pointed end of the nylon spudger, carefully pry an edge of the battery, and lift the battery from its socket.
  4. Casio FX-115MS Individual Keys Replacement, Motherboard and Screen: 4 단계, 이미지 2개 중 1개 Casio FX-115MS Individual Keys Replacement, Motherboard and Screen: 4 단계, 이미지 2개 중 2개
    • Using the plastic spudger, carefully pry the battery terminals from the front plate. If the plastic spudger is too weak for prying out the terminals, use the small metal spudger.By Carefully bending and/or prying the little teeth on the terminals upwards you can easily remove them.
  5. Casio FX-115MS Individual Keys Replacement: 5 단계, 이미지 3개 중 1개 Casio FX-115MS Individual Keys Replacement: 5 단계, 이미지 3개 중 2개 Casio FX-115MS Individual Keys Replacement: 5 단계, 이미지 3개 중 3개
    • Using the small metal spudger. Carefully pry around the edge of the solar panel until it becomes loose. Then simply pull it from its socket using your hands.
  6. Casio FX-115MS Individual Keys Replacement: 6 단계, 이미지 2개 중 1개 Casio FX-115MS Individual Keys Replacement: 6 단계, 이미지 2개 중 2개
    • Using a PH0 phillips screwdriver, unscrew the four, 4mm, pan head screws from the motherboard.
  7. Casio FX-115MS Individual Keys Replacement: 7 단계, 이미지 3개 중 1개 Casio FX-115MS Individual Keys Replacement: 7 단계, 이미지 3개 중 2개 Casio FX-115MS Individual Keys Replacement: 7 단계, 이미지 3개 중 3개
    • Carefully lift the motherboard, screen, solar panel, and battery terminal combination from the front plate. Start from the motherboard and lift at an angle toward the solar panel.
  8. Casio FX-115MS Individual Keys Replacement, Keyboard Mat: 8 단계, 이미지 3개 중 1개 Casio FX-115MS Individual Keys Replacement, Keyboard Mat: 8 단계, 이미지 3개 중 2개 Casio FX-115MS Individual Keys Replacement, Keyboard Mat: 8 단계, 이미지 3개 중 3개
    • Starting from one corner of the keyboard mat, slowly peel the mat from the front plate and individual keys.
  9. Casio FX-115MS Individual Keys Replacement, Individual Keys: 9 단계, 이미지 3개 중 1개 Casio FX-115MS Individual Keys Replacement, Individual Keys: 9 단계, 이미지 3개 중 2개 Casio FX-115MS Individual Keys Replacement, Individual Keys: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Select which key you need to remove, then using the Angled ESD Tweezers pick up the key, and pull it free from the face plate.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Fady Baskharoun
회원 가입일: 10/04/16
274 평판
안내서 2개를 작성함
USF Tampa, Team 2-2, Nance Fall 2016 USF Tampa, Team 2-2, Nance Fall 2016 회원
USFT-NANCE-F16S2G2
4 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 47
전체 시간: 1,969
