주요 콘텐츠로 건너뛰기
Casio FX-991ES Plus Battery Replacement
필요한 것
  1. Casio FX-991ES Plus Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the calculator is off. If not, turn it off by pressing the [Shift] button then the [AC] [OFF] button.
  2. Casio FX-991ES Plus Battery Replacement: 2 단계, 이미지 1/1
    • Flip the calculator upside down and lay it on a flat surface.
    • Do not press hard on the calculator to avoid turning it on by mistake.
  3. Casio FX-991ES Plus Battery Replacement: 3 단계, 이미지 1/2 Casio FX-991ES Plus Battery Replacement: 3 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to unscrew the 1.6 mm screw on the battery cover.
    • Remove the battery cover.
    • Be gentle while unscrewing the cover, to avoid damaging it.
  4. Casio FX-991ES Plus Battery Replacement: 4 단계, 이미지 1/3 Casio FX-991ES Plus Battery Replacement: 4 단계, 이미지 2/3 Casio FX-991ES Plus Battery Replacement: 4 단계, 이미지 3/3
    • Use a spudger to remove the old battery. Insert it in the empty slot to pry out the battery.
    • Do not use a sharp item like a knife.
    • Do not use metal tools, to avoid damaging parts of the battery compartment.
  5. Casio FX-991ES Plus Battery Replacement: 5 단계, 이미지 1/1
    • Place the new battery into the compartment with the positive (+) side facing upwards.
  6. Casio FX-991ES Plus Battery Replacement: 6 단계, 이미지 1/1
    • Attach the battery cover and tighten the screw with a Phillips #0 screwdriver.
  7. Casio FX-991ES Plus Battery Replacement: 7 단계, 이미지 1/1
    • To reset the calculator, press the [ON] button.
    • Press the [SHIFT] button.
    • Press the [9] [CLR] button to clear the data.
    • Press the [3] button to choose "ALL".
    • Press the [=] button to agree.
    • Press the [AC] button
결승점
다른 11명이 해당 안내서를 완성하였습니다.
Zinab Alhamoud
회원 가입일: 01/17/21
463 평판
안내서 1개 작성함
York University, Team S1-G4, O'Regan Winter 2021 York University, Team S1-G4, O'Regan Winter 2021 회원
YORK-O'REGAN-W21S1G4
1 회원
안내서 5개 작성하였습니다
댓글 4개
Thank you so much! God bless you.
Igor Diniz - 답글
Can you send me one please
In Jaigaon india
chandra giri - 답글
La touche ON de ma calculatrice ne fonctionne plus comment faire ?
Emmanuel Prosper - 답글
댓글 쓰기
조회 통계:
24 시간 전: 60
7일 전: 339
30일 전: 1,615
전체 시간: 55,387
