주요 콘텐츠로 건너뛰기
Casio G'zOne Commando Verizon MIL-SPEC Sim Card Replacement
필요한 것
  1. Casio G'zOne Commando Verizon MIL-SPEC Sim Card Replacement, Battery: 1 단계, 이미지 1/1
    • Slide the slider on the back of the phone to the free position.
  2. Casio G'zOne Commando Verizon MIL-SPEC Sim Card Replacement: 2 단계, 이미지 1/1
    • Using a plastic opening tool, gently lift open the back panel from bottom of the panel.
  3. Casio G'zOne Commando Verizon MIL-SPEC Sim Card Replacement: 3 단계, 이미지 1/2 Casio G'zOne Commando Verizon MIL-SPEC Sim Card Replacement: 3 단계, 이미지 2/2
    • Pull the white battery tab upwards and remove the battery.
  4. Casio G'zOne Commando Verizon MIL-SPEC Sim Card Replacement, Sim Card: 4 단계, 이미지 1/1
    • Using a spudger, gently open the metal tab up. Now, it is ready for you to insert the new SIM card.
결론
Zack Almeida
회원 가입일: 10/24/18
392 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S3-G7, Peak Fall 2018 UMass Dartmouth, Team S3-G7, Peak Fall 2018 회원
UMASSD-PEAK-F18S3G7
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
i believe that is the memory card, not the sim card!
Joshua Vaillancourt - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 27
전체 시간: 2,389
