주요 콘텐츠로 건너뛰기
Casio G’zOne Commando 4G LTE Battery Replacement
필요한 것
  1. Casio G’zOne Commando 4G LTE Battery Replacement, Battery: 1 단계, 이미지 1/1
    • In order to get at the battery, you will have to pull the locking tab to the “Free” position. Once you do that you will have to pry the battery cover off (using a plastic opening tool or similar prying tool). Because the phone is designed to be waterproof, it is advised that you do NOT use your fingernails.
  2. Casio G’zOne Commando 4G LTE Battery Replacement: 2 단계, 이미지 1/2 Casio G’zOne Commando 4G LTE Battery Replacement: 2 단계, 이미지 2/2
    • Once the battery cover is off, there is another lock holding the battery in place. However, with this lock all you have to do is slide the lock to “Free”, and pull the battery out by lifting it from the bottom side (the side with the orange lock).
결론
To install a new battery in your device, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Daniel Keenan
회원 가입일: 10/28/15
374 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 1-9, Miles Fall 2015 UMass Dartmouth, Team 1-9, Miles Fall 2015 회원
UMASSD-MILES-F15S1G9
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 10
전체 시간: 737
