주요 콘텐츠로 건너뛰기
Casio G’zOne Commando 4G LTE Camera Replacement
필요한 것
  1. Casio G’zOne Commando 4G LTE Camera Replacement, Motherboard: 1 단계, 이미지 1/1
    • First, you are going to want to take out the two front screws from the device.
    • The screws are 4mm in length and require a Y0 bit to remove
  2. Casio G’zOne Commando 4G LTE Camera Replacement: 2 단계, 이미지 1/1
    • Using the same screw head, remove the back four screws from the device.
  3. Casio G’zOne Commando 4G LTE Camera Replacement: 3 단계, 이미지 1/2 Casio G’zOne Commando 4G LTE Camera Replacement: 3 단계, 이미지 2/2
    • You should have taken out six screws (two from the front, four from the back). Once you do this, you will have to separate the front and back casing of the phone using a spudger or pry tool.
  4. Casio G’zOne Commando 4G LTE Camera Replacement: 4 단계, 이미지 1/1
    • Now, you have six more screws to unscrew (three on each side). They are all the same size but smaller than the first six we took off.
    • These screws are 4mm in length and require a PH00 tip to remove.
  5. Casio G’zOne Commando 4G LTE Camera Replacement: 5 단계, 이미지 1/1
    • Once you unscrew all six screws, you can easily separate the plastic shell with your hands.
  6. Casio G’zOne Commando 4G LTE Camera Replacement: 6 단계, 이미지 1/2 Casio G’zOne Commando 4G LTE Camera Replacement: 6 단계, 이미지 2/2
    • Again, there are six more (and even smaller) screws to take out. Additionally, you have to disconnect a small wire plugged into the motherboard.
    • These screws are 2mm in length and require a PH000 tip to remove.
  7. Casio G’zOne Commando 4G LTE Camera Replacement: 7 단계, 이미지 1/2 Casio G’zOne Commando 4G LTE Camera Replacement: 7 단계, 이미지 2/2
    • After removing the screws carefully separate the motherboard from the shell with the spudger.
  8. Casio G’zOne Commando 4G LTE Camera Replacement, Camera: 8 단계, 이미지 1/1
    • In order to remove the camera, carefully disconnect the wires with the metal spudger.
  9. Casio G’zOne Commando 4G LTE Camera Replacement: 9 단계, 이미지 1/3 Casio G’zOne Commando 4G LTE Camera Replacement: 9 단계, 이미지 2/3 Casio G’zOne Commando 4G LTE Camera Replacement: 9 단계, 이미지 3/3
    • After disconnecting the wires, remove the camera by putting slight pressure of the optical camera lens. The camera the will pop out of the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Keith Hickey
회원 가입일: 10/29/15
428 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 1-9, Miles Fall 2015 UMass Dartmouth, Team 1-9, Miles Fall 2015 회원
UMASSD-MILES-F15S1G9
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 5
전체 시간: 411
