소개
After removing the battery and motherboard from your device you will be able to simply remove the camera from the mother board after following the steps provided.
필요한 것
First, you are going to want to take out the two front screws from the device.
The screws are 4mm in length and require a Y0 bit to remove
In order to remove the camera, carefully disconnect the wires with the metal spudger.
다른 한 분이 해당 안내서를 완성하였습니다.
