소개
After removing the battery and motherboard from your device you will be able to easily remove the head phone port by following the steps below
필요한 것
First, you are going to want to take out the two front screws from the device.
The screws are 4mm in length and require a Y0 bit to remove
In order to remove the audio port remove the two screws located on either side of the Audio receiver using the philips head J000 tip.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
How do you view this? It says follow the steps below but it won't let you go below.
