주요 콘텐츠로 건너뛰기
Casio G’zOne Commando 4G LTE Motherboard Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Casio G’zOne Commando 4G LTE Motherboard Replacement, Open back cover.: 1 단계, 이미지 1/1
    • This device is waterproof and well sealed, so it is difficult to open this handset.
    • Start by opening the cover of the handset.
    • Do not use your nails to open the cover. Use the iFixit Opening Tool (refer to the image).
  2. Casio G’zOne Commando 4G LTE Motherboard Replacement, Free and remove the battery: 2 단계, 이미지 1/2 Casio G’zOne Commando 4G LTE Motherboard Replacement, Free and remove the battery: 2 단계, 이미지 2/2
    • Move the orange tab to the right side to take out the battery.
    • Remove the battery.
  3. Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove front and back screws: 3 단계, 이미지 1/2 Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove front and back screws: 3 단계, 이미지 2/2
    • Using the Phillips #00 screwdriver remove the front and back 5.0 mm screws as shown in the picture.
    • There are four screws in the back and two screws in the front.
  4. Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove side-Back cover: 4 단계, 이미지 1/3 Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove side-Back cover: 4 단계, 이미지 2/3 Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove side-Back cover: 4 단계, 이미지 3/3
    • Gently remove the side cover from the phone by lifting up on the corners as shown in the picture.
    • Press down on the screen to help remove the plastic side cover from the phone.
    • Make sure to push gently because the frame is fragile.
  5. Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove Side-Front cover: 5 단계, 이미지 1/1
    • Pull the side front cover off the face of the phone.
  6. Casio G’zOne Commando 4G LTE Motherboard Replacement: 6 단계, 이미지 1/3 Casio G’zOne Commando 4G LTE Motherboard Replacement: 6 단계, 이미지 2/3 Casio G’zOne Commando 4G LTE Motherboard Replacement: 6 단계, 이미지 3/3
    • Remove the eight 2.5mm Phillips #00 screws in the holes of the casing.
  7. Casio G’zOne Commando 4G LTE Motherboard Replacement: 7 단계, 이미지 1/1
    • Gently pull off the motherboard cover.
  8. Casio G’zOne Commando 4G LTE Motherboard Replacement: 8 단계, 이미지 1/1
    • Using the Phillips #00, remove all 2.5 mm screws attached to the motherboard.
    • Do not touch the integrated circuits in the motherboard.
  9. Casio G’zOne Commando 4G LTE Motherboard Replacement, Motherboard: 9 단계, 이미지 1/2 Casio G’zOne Commando 4G LTE Motherboard Replacement, Motherboard: 9 단계, 이미지 2/2
    • Gently remove the motherboard with the spudger.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Brett Boehm
회원 가입일: 09/25/14
281 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-5, Brown Fall 2014 USF Tampa, Team 1-5, Brown Fall 2014 회원
USFT-BROWN-F14S1G5
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 853
