주요 콘텐츠로 건너뛰기
Casio G’zOne Commando 4G LTE Sim Card Replacement
필요한 것
  1. Casio G’zOne Commando 4G LTE Sim Card Replacement, Battery: 1 단계, 이미지 1/1
    • In order to get at the battery, you will have to pull the locking tab to the “Free” position. Once you do that you will have to pry the battery cover off (using a plastic opening tool or similar prying tool). Because the phone is designed to be waterproof, it is advised that you do NOT use your fingernails.
  2. Casio G’zOne Commando 4G LTE Sim Card Replacement: 2 단계, 이미지 1/2 Casio G’zOne Commando 4G LTE Sim Card Replacement: 2 단계, 이미지 2/2
    • Once the battery cover is off, there is another lock holding the battery in place. However, with this lock all you have to do is slide the lock to “Free”, and pull the battery out by lifting it from the bottom side (the side with the orange lock).
  3. Casio G’zOne Commando 4G LTE Sim Card Replacement, Sim Card: 3 단계, 이미지 1/1
    • After removing the battery you will find a port that is labeled SIM directly beneath where the battery was sitting.
  4. Casio G’zOne Commando 4G LTE Sim Card Replacement: 4 단계, 이미지 1/1
    • In order to remove the SD card lift the tab that is located directly to the left of the card. Then slide the SD card out of its port and remove it from the cell phone.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Keith Hickey
회원 가입일: 10/29/15
428 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 1-9, Miles Fall 2015 UMass Dartmouth, Team 1-9, Miles Fall 2015 회원
UMASSD-MILES-F15S1G9
3 회원들
안내서 10개 작성하였습니다
댓글 2개
My Casio C811 will not go to a browser, keeps saying no network connection. I am in an area that I have had connection with no problems before. The phone did some sort of reset on it own and now wont access any browser, google, Facebook ect. I have check the network setting and they appear OK. Any suggestions
bernmntsa - 답글
How do I unlock my Casio Commando C811 to use with non-verizon SIM…!?
Alrn Arun - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 30
전체 시간: 4,550
