주요 콘텐츠로 건너뛰기
Casio G’zOne Commando 4G LTE Volume Buttons Replacement
필요한 것
  1. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove front and back screws: 1 단계, 이미지 1/2 Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove front and back screws: 1 단계, 이미지 2/2
    • Using the Phillips #00 screwdriver remove the front and back 5.0 mm screws as shown in the picture.
    • There are four screws in the back and two screws in the front.
  2. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove side-Back cover: 2 단계, 이미지 1/3 Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove side-Back cover: 2 단계, 이미지 2/3 Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove side-Back cover: 2 단계, 이미지 3/3
    • Gently remove the side cover from the phone by lifting up on the corners as shown in the picture.
    • Press down on the screen to help remove the plastic side cover from the phone.
    • Make sure to push gently because the frame is fragile.
  3. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Remove Side-Front cover: 3 단계, 이미지 1/1
    • Pull the side front cover off the face of the phone.
  4. Casio G’zOne Commando 4G LTE Volume Buttons Replacement: 4 단계, 이미지 1/3 Casio G’zOne Commando 4G LTE Volume Buttons Replacement: 4 단계, 이미지 2/3 Casio G’zOne Commando 4G LTE Volume Buttons Replacement: 4 단계, 이미지 3/3
    • Remove the eight 2.5mm Phillips #00 screws in the holes of the casing.
  5. Casio G’zOne Commando 4G LTE Volume Buttons Replacement: 5 단계, 이미지 1/1
    • Gently pull off the motherboard cover.
  6. Casio G’zOne Commando 4G LTE Volume Buttons Replacement: 6 단계, 이미지 1/1
    • Using the Phillips #00, remove all 2.5 mm screws attached to the motherboard.
    • Do not touch the integrated circuits in the motherboard.
  7. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Motherboard: 7 단계, 이미지 1/2 Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Motherboard: 7 단계, 이미지 2/2
    • Gently remove the motherboard with the spudger.
  8. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Removing external volume pads: 8 단계, 이미지 1/2 Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Removing external volume pads: 8 단계, 이미지 2/2
    • Following step 4 in the prerequisite guide, remove the volume pads located on the side of the phone with a gentle pull.
  9. Casio G’zOne Commando 4G LTE Volume Buttons Replacement, Removing internal volume buttons: 9 단계, 이미지 1/1
    • Following step 6, remove the adapter connecting the volume buttons to the motherboard.
결론
Brett Boehm
회원 가입일: 09/25/14
281 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-5, Brown Fall 2014 USF Tampa, Team 1-5, Brown Fall 2014 회원
USFT-BROWN-F14S1G5
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 145
