주요 콘텐츠로 건너뛰기
Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement
필요한 것
  1. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Slide the slider on the back of the phone to the free position.
  2. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: 2 단계, 이미지 1/1
    • Using a plastic opening tool, gently lift open the back panel from bottom of the panel.
  3. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: 3 단계, 이미지 1/2 Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: 3 단계, 이미지 2/2
    • Pull the white battery tab upwards and remove the battery.
  4. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement, Motherboard: 4 단계, 이미지 1/1
    • Remove the four 6mm Y0 screws from the corners of the device.
  5. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the four 5mm Y0 screws from the back of the device.
  6. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: 6 단계, 이미지 1/1
    • Using a spudger, pry away the motherboard from its compartment, by inserting the spudger in the compartment and lifting upwards until fully out.
  7. Casio G'zOne Commando Verizon MIL-SPEC Motherboard Replacement: 7 단계, 이미지 1/1
    • Lastly, using your hands, separate the motherboard from its compartment.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Zack Almeida
회원 가입일: 10/24/18
392 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S3-G7, Peak Fall 2018 UMass Dartmouth, Team S3-G7, Peak Fall 2018 회원
UMASSD-PEAK-F18S3G7
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 195
