주요 콘텐츠로 건너뛰기
Casio G-Shock G8900A-1CR Battery Replacement.
필요한 것
  1. Casio G-Shock G8900A-1CR Battery Replacement., Battery: 1 단계, 이미지 3개 중 1개 Casio G-Shock G8900A-1CR Battery Replacement., Battery: 1 단계, 이미지 3개 중 2개 Casio G-Shock G8900A-1CR Battery Replacement., Battery: 1 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to unscrew the four 2.0mm screws on the back cover of the watch.
  2. Casio G-Shock G8900A-1CR Battery Replacement.: 2 단계, 이미지 2개 중 1개 Casio G-Shock G8900A-1CR Battery Replacement.: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the back cover.
    • Use tweezers to remove the rubber gasket.
  3. Casio G-Shock G8900A-1CR Battery Replacement.: 3 단계, 이미지 1개 중 1개
    • Use tweezers to remove the rubber cover.
  4. Casio G-Shock G8900A-1CR Battery Replacement.: 4 단계, 이미지 2개 중 1개 Casio G-Shock G8900A-1CR Battery Replacement.: 4 단계, 이미지 2개 중 2개
    • Use tweezers to press in the gap in the opening of the battery protection.
    • The battery protection should pop open.
    • Do not apply too much force.
    • Raise the battery protection.
  5. Casio G-Shock G8900A-1CR Battery Replacement.: 5 단계, 이미지 1개 중 1개
    • Use tweezers to remove the old CR2016 3V battery.
    • Avoid using your fingers for the process to prevent static discharge and potential damage.
  6. Casio G-Shock G8900A-1CR Battery Replacement.: 6 단계, 이미지 2개 중 1개 Casio G-Shock G8900A-1CR Battery Replacement.: 6 단계, 이미지 2개 중 2개
    • Insert the new CR2016 3V battery into the compartment.
    • Align the new battery's positive and negative sides with the orientation of the previous one.
    • Close the battery protection by gently pressing on it.
    • Press until it audibly clicks into place.
  7. Casio G-Shock G8900A-1CR Battery Replacement.: 7 단계, 이미지 1개 중 1개
    • Put the rubber gasket and cover back in their original position, and tighten the four 2.0mm screws using a Phillips #00 screwdriver.
  8. Casio G-Shock G8900A-1CR Battery Replacement.: 8 단계, 이미지 1개 중 1개
    • Press the [ADJUST] button until the seconds starts blinking.
    • Press the [MODE] button to go through the settings until you get to the hour, minute, and seconds adjustment.
    • Press the [FORWARD] button to scroll forwards, for example, from 9 to 10 o'clock.
    • Press the [REVERSE] button to scroll backwards, for example, from 10 to 9 o'clock.
    • For more features and settings, consult the user manual.
결론
When you need to dispose of your CR2016 3V battery, please take them to a battery recycling center, use a battery drop-off location, or arrange a battery pick-up through your local government's website.
작성자
2다른 기여자 명과 함께
Stephen
회원 가입일: 09/11/23
157 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 45
지난 30일: 164
전체 시간: 2,536
