주요 콘텐츠로 건너뛰기
Casio LK-170 Button Replacement
필요한 것
  1. Casio LK-170 Button Replacement, Button: 1 단계, 이미지 2개 중 1개 Casio LK-170 Button Replacement, Button: 1 단계, 이미지 2개 중 2개
    • Using a JIS-1 screwdriver, remove the seven 11 mm screws located on the back of the keyboard.
  2. Casio LK-170 Button Replacement: 2 단계, 이미지 1개 중 1개
    • Once all the screws are out, flip the keyboard over and gently pull the middle panel out.
    • Flip the middle panel up so that the component board can be seen.
  3. Casio LK-170 Button Replacement: 3 단계, 이미지 3개 중 1개 Casio LK-170 Button Replacement: 3 단계, 이미지 3개 중 2개 Casio LK-170 Button Replacement: 3 단계, 이미지 3개 중 3개
    • In this step, you will be removing a total of 26 screws.
    • First, you will use a PH-1 bit to remove the 17 8mm screws circled in red.
    • Next, using the same PH-1 bit, you will remove the three 8mm screws hidden under the white wires, circled in orange.
    • Then, using a JIS-1 bit, we will remove three 7mm screws from the circuit board, circled in yellow.
    • After removing the circuit board, the last three screws are revealed, circled in green. You will use the PH-1 bit to remove these last screws.
  4. Casio LK-170 Button Replacement: 4 단계, 이미지 1개 중 1개
    • Once all the screws have been removed, lift the panel and place it face down on the keys.
    • The panel is connected to the keyboard, so do not try to remove it.
  5. Casio LK-170 Button Replacement: 5 단계, 이미지 2개 중 1개 Casio LK-170 Button Replacement: 5 단계, 이미지 2개 중 2개
    • Under the panel are the buttons. Remove them by pulling from any corner with your fingers.
    • Remove all the buttons that need to be replaced.
결론
작성자
3다른 기여자 명과 함께
Eileen Tran
회원 가입일: 01/24/17
108 평판
안내서 1개를 작성함
Cal Poly, Team 13-2, Banghart Winter 2017 Cal Poly, Team 13-2, Banghart Winter 2017 회원
CPSU-BANGHART-W17S13G2
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 679
