주요 콘텐츠로 건너뛰기
Casio LK-170 Display Replacement
필요한 것
  1. Casio LK-170 Display Replacement, Display: 1 단계, 이미지 1개 중 1개
    • Using JIS-1 screwdriver, remove the seven 11mm screws located on the back of the keyboard.
  2. Casio LK-170 Display Replacement: 2 단계, 이미지 1개 중 1개
    • Once all the screws are out, flip the keyboard over and gently pull the middle panel out.
    • Flip this panel up so that the component board can be seen.
  3. Casio LK-170 Display Replacement: 3 단계, 이미지 3개 중 1개 Casio LK-170 Display Replacement: 3 단계, 이미지 3개 중 2개 Casio LK-170 Display Replacement: 3 단계, 이미지 3개 중 3개
    • We will be removing a total of 26 screws on the component board..
    • First, you must use the PH-1 bit to remove the 17 8mm screws, circled in red.
    • Second, using the same PH-1 bit, you will remove the three 8mm screws hidden under the white wire. These screws are circled in orange.
    • Third, using the JIS-1 bit, remove the three 7mm screws on the circuit board.
    • After removing the circuit board, three more screws will be revealed.
    • Using the PH-1 bit, remove the last three 8mm screws, circled in green.
  4. Casio LK-170 Display Replacement: 4 단계, 이미지 1개 중 1개
    • Once all the screws have been removed, lift the component board and place it face down on the keys.
    • The component board is connected to the keyboard, so do not try to remove it.
  5. Casio LK-170 Display Replacement: 5 단계, 이미지 1개 중 1개
    • Flip over the component board to reveal the display that is currently connected to a green panel.
  6. Casio LK-170 Display Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the display by carefully picking it up with your fingers from the green panel.
결론
작성자
3다른 기여자 명과 함께
Samantha Baker
회원 가입일: 01/24/17
443 평판
안내서 4개를 작성함
Cal Poly, Team 13-2, Banghart Winter 2017 Cal Poly, Team 13-2, Banghart Winter 2017 회원
CPSU-BANGHART-W17S13G2
3 회원들
안내서 5개를 작성함
1가이드 댓글
Hey, where do you find a replacement lcd?
Albert istvab - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 10
전체 시간: 790
