주요 콘텐츠로 건너뛰기
Casio SPF-40 2273 Battery Replacement
필요한 것
  1. Casio SPF-40 2273 Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Casio SPF-40 2273 Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Casio SPF-40 2273 Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • This super strong Casio watch is more docile than waht you might think.
    • We don't need to twist off the front's screws.
    • It doesn't bite, so let's turn it around
  2. Casio SPF-40 2273 Battery Replacement: 2 단계, 이미지 3개 중 1개 Casio SPF-40 2273 Battery Replacement: 2 단계, 이미지 3개 중 2개 Casio SPF-40 2273 Battery Replacement: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • With the phillips screwdriver take off these four screws
    • Lift up an extremity of the watchstrap and remove the base.
    • You can use a flat screwdriver to help you
    • With the tweezers lift the white plastic cover
    • Be careful to not damage the golden springs!! So take your time
  3. Casio SPF-40 2273 Battery Replacement: 3 단계, 이미지 3개 중 1개 Casio SPF-40 2273 Battery Replacement: 3 단계, 이미지 3개 중 2개 Casio SPF-40 2273 Battery Replacement: 3 단계, 이미지 3개 중 3개
    • With the tip of the tweezers you have to unclip the clips into the red rectangles.
    • Just insert the tweezer's tip in the center of the bracket and pull toward the center of the watch
  4. Casio SPF-40 2273 Battery Replacement: 4 단계, 이미지 3개 중 1개 Casio SPF-40 2273 Battery Replacement: 4 단계, 이미지 3개 중 2개 Casio SPF-40 2273 Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Extract the battery leveraging with the tweezers.
    • Keep attention to the golden springs again!
    • The clip, holding down the central batteries, completely removes
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Acn0w
회원 가입일: 09/20/18
15,795 평판
안내서 1개를 작성함
5가이드 댓글
cannot see the “Golden Springs”. Where are they? Thank you
mike.malapascua - 답글
would be nice to have a description if the battery type, to buy before disassembling.. Thank you
mike
Sorry if I wasn’t imprecise, the “Golden Springs” is located above the first battery on the left. More precisely in second step of the guide I marked it.
Coin shaped Batteries are Sony SR927W:
* 1.55 Volt
* 60 mAh
Acn0w -
What about the sticker „After battery replacment, contact AC with battery(+) using tweezers“ ?
ameyer - 답글
Come devo riavviare? Non si accende grazie
stefano chirio - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 25
지난 30일: 146
전체 시간: 12,267
