주요 콘텐츠로 건너뛰기
Casio Watchband link replacement/repair
필요한 것
  1. Casio Watchband link replacement/repair, Links: 1 단계, 이미지 1/2 Casio Watchband link replacement/repair, Links: 1 단계, 이미지 2/2
    • Locate the hole for the pin you would like to remove.
    • Insert the Sim Card Eject tool (a safety pin may work as well) inthe hole. Make sure to insert in the hole on the back side of the arrow.
  2. Casio Watchband link replacement/repair: 2 단계, 이미지 1/1
    • Determine the desired amount of links you would like to add or remove.
  3. Casio Watchband link replacement/repair: 3 단계, 이미지 1/1
    • To remove links:
    • Use the same process used in Step 2 to remove the second link pin.
    • The two link pins and the links should now be detached.
  4. Casio Watchband link replacement/repair: 4 단계, 이미지 1/1
    • To add links:
    • Push both link pins back into the watch. Make sure to insert the link pin on the front side of the arrow.
    • Lightly tap a hammer until pins are flush against both sides of the watchband.
    • When adding links, be sure to insert the links at the same time as the link pins.
  5. Casio Watchband link replacement/repair: 5 단계, 이미지 1/1
    • For micro adjustments, push the Sim Card Eject tool into the adjustable side of the clasp. Carefully move pins to the correct fitting holes.
    • Do your best to not let the pins slip outside the metal clasp as they are difficult to get back in.
  6. Casio Watchband link replacement/repair: 6 단계, 이미지 1/3 Casio Watchband link replacement/repair: 6 단계, 이미지 2/3 Casio Watchband link replacement/repair: 6 단계, 이미지 3/3
    • Insert spring into the spring bar.
    • Insert the spring bar pin on both sides of the spring in the spring bar.
    • This is the spring bar pin.
  7. Casio Watchband link replacement/repair: 7 단계, 이미지 1/2 Casio Watchband link replacement/repair: 7 단계, 이미지 2/2
    • Put the spring bar and spring bar pins through the end of the clasp.
    • Guide one spring bar pin into the hole on the clasp shell. Hold your finger on the other side of the spring bar to keep the parts together.
  8. Casio Watchband link replacement/repair: 8 단계, 이미지 1/2 Casio Watchband link replacement/repair: 8 단계, 이미지 2/2
    • Squeeze the spring bar so it fits within the metal sides of the clasp.
    • Guide the other side of the spring bar into the other hole.
결론
To disassemble the clasp, follow the last 3 steps in reverse order.
다른 8명이 해당 안내서를 완성하였습니다.
Zach Monroe
회원 가입일: 09/29/15
336 평판
안내서 1개 작성함
Cal Poly, Team 10-3, Green Fall 2015 Cal Poly, Team 10-3, Green Fall 2015 회원
CPSU-GREEN-F15S10G3
4 회원들
안내서 4개 작성하였습니다
댓글 3개
These are good tips. Repairing a watch can be tricky especially if moisture creeps in. If you're stuck for help, check out http://TimesTicking.com I have used them many times. Very helpful!
Annette Foster - 답글
Hi, where can I buy link pins? I have the ones with the spring, but the others - I have not been able to find online.
zhivko.nachev - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 22
30일 전: 94
전체 시간: 11,058
