주요 콘텐츠로 건너뛰기
Casio MH-10M Battery Replacement
필요한 것
  1. Casio MH-10M Battery Replacement, BATTERY: 1 단계, 이미지 1/1
    • This is the calculator in question.
    • Features a black and white dot matrix screen.
  2. Casio MH-10M Battery Replacement: 2 단계, 이미지 1/2 Casio MH-10M Battery Replacement: 2 단계, 이미지 2/2
    • Turn the calculator over.
    • Locate the six screws on the rear of the device.
    • These are Philips #00 screws.
    • Keep the screws you remove in a safe place so they don't get lost.
  3. Casio MH-10M Battery Replacement: 3 단계, 이미지 1/2 Casio MH-10M Battery Replacement: 3 단계, 이미지 2/2
    • Once the screws are removed, carefully lift the back panel off, lifting the top end first.
    • Place the panel to one side.
    • You can now see the battery.
  4. Casio MH-10M Battery Replacement: 4 단계, 이미지 1/1
    • Remove the battery
    • Lift it up from the right hand side to avoid damaging the spring.
    • You may find this easier to do by prying it out with the screwdriver.
  5. Casio MH-10M Battery Replacement: 5 단계, 이미지 1/2 Casio MH-10M Battery Replacement: 5 단계, 이미지 2/2
    • Now you can insert the new battery
    • Ensure you place it in spring-first.
    • Congratulations! You have replaced the battery.
    • When reassembling, take care not to trap the red or black wires in the screws as this would sever them, making the calculator unusable.
    • Once reassembled, the calculator will be turned on. Turn it off to save battery by pressing Shift --> AC.
결론
To reassemble your device, follow these instructions in reverse order, noting the two reassembly instructions in the last step.
다른 26명이 해당 안내서를 완성하였습니다.
Sam
회원 가입일: 09/23/12
959 평판
안내서 1개 작성함
댓글 3개
For some reason the two top screws made the calculator unstable, but removing them made it stable. Only occurred after removing the battery
Mida Galbraith - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 49,209
