주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
부품
  1. This is the calculator in question.
    • This is the calculator in question.
    • Features a black and white dot matrix screen.
  2. Turn the calculator over. Locate the six screws on the rear of the device.
    • Turn the calculator over.
    • Locate the six screws on the rear of the device.
    • These are Philips #00 screws.
    • Keep the screws you remove in a safe place so they don't get lost.
  3. Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
    Nintendo Switch 키트 쇼핑하기
    Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
  4. Once the screws are removed, carefully lift the back panel off, lifting the top end first. Place the panel to one side.
    • Once the screws are removed, carefully lift the back panel off, lifting the top end first.
    • Place the panel to one side.
    • You can now see the battery.
  5. Remove the battery
    • Remove the battery
    • Lift it up from the right hand side to avoid damaging the spring.
    • You may find this easier to do by prying it out with the screwdriver.
  6. Now you can insert the new battery Ensure you place it in spring-first.
    • Now you can insert the new battery
    • Ensure you place it in spring-first.
    • Congratulations! You have replaced the battery.
    • When reassembling, take care not to trap the red or black wires in the screws as this would sever them, making the calculator unusable.
    • Once reassembled, the calculator will be turned on. Turn it off to save battery by pressing Shift --> AC.
결론
To reassemble your device, follow these instructions in reverse order, noting the two reassembly instructions in the last step.
다른 25명이 해당 안내서를 완성하였습니다.
Sam
회원 가입일: 2012년 09월 23일
923 평판
안내서 1개 작성함
For some reason the two top screws made the calculator unstable, but removing them made it stable. Only occurred after removing the battery
Mida Galbraith - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 94
30일 전: 368
전체 시간: 42,663
